Build history Options
SandyM
#1 Posted : 25 September 2012 18:01:28
Various balsa aircraft both rubber powered and RC
Billing Jylland
Billing. Wasa
Billing. Dutch Royal Barge (gold medal winer Germany 1975)
Scratch built HMS Victory made from old timber from the Victory using HMSO plans hull size 26"
Scratch built Yamato hull size 8'8"
De Pardo HMS Bounty
Looking forward to building the Sovereign of the Seas
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
#2 Posted : 25 September 2012 18:05:34
Look forward to seeing your build Sandy Cool
court orchard
#3 Posted : 22 November 2012 11:14:10
Hi Sandy,
Fantastic job on the Launch. As you say a much better match for those in the contemporary pictures, which do all seem to have that profile.
#4 Posted : 22 November 2012 13:52:16
Hi Sandy, Nice jobBigGrin Regards Mike
farrabass
#5 Posted : 22 November 2012 16:27:24
Nice details!! I look forward to the completed boat.
Steve..
#6 Posted : 22 November 2012 22:04:01
Nice work Sandy....
SandyM
#7 Posted : 22 November 2012 23:56:55
Thanks a lot guys.
Like I said I have a good few weeks until we see how the stern is shaping up before I start on the ship. Plenty of time to horn the launch a bit.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
NMBROOK
#8 Posted : 10 December 2012 01:52:00
Hi Sandy nice job on the launch,it seems a shame to paint it,id be tempted to clear varnish the inside of the boat and only paint the outside.I havent started mine yet,and still tempted to plank clinker style,but i'll have to wait for the brass decoration because the uppermost plank needs to be the same size as this.I pretty much in the same position as you,waiting for more issues in advance before i really get stuck in.I have managed to find some 4mm wide boxwood for planking the upper hull.I plan on making the wales in walnut.
In the meantime im in deep with my sergal soleil royal(heavily modified)
Regards Nigel
court orchard
#9 Posted : 10 January 2013 12:49:38
Hi Sandy,
Your image link doesn't work, it looks like you might have pasted your images in the wrong spot rather than between the 2 [img] markers.
I've done that a few times, I always preview my posts first now.
#10 Posted : 11 January 2013 09:12:35
Sandy, as Andy has already pointed out following your previous post, your image links don't work, it appears you might have pasted your images in the wrong spot rather than between the two [img] brackets.
SandyM
#11 Posted : 11 January 2013 09:40:01
Sorry guys don't know what's going on image size is 300x200 pixels and I have ensured that the brackets don't disappear.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
Admiral Anti Spiral
#12 Posted : 11 January 2013 14:07:11
Best way i know is the to simply upload it to photobucket and copy the image url from there.
Processing - Progressing
Previous builds: HMS Victory
SandyM
#13 Posted : 12 January 2013 13:14:29
Trying Photobucket they don't load in
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
court orchard
#14 Posted : 12 January 2013 13:25:35
Hi Sandy,
I'm really keen to see your photos.
I use Photobucket for all my posts and it works fine.
This what I do. See post 3.
http://forum.model-space.co.uk/....aspx?g=posts&t=5783
#15 Posted : 13 January 2013 01:05:52
BigGrin Hi Sandy
If your using a digital camera and it came with software just resize on the software on your pc and load directly from your pc using the browse button as you post , that's how I get my pics up. hope this helps
SandyM
#16 Posted : 13 January 2013 15:21:40
Thanks Guys for all your help
Amended Stern Castle. Still to be tidied up and clad with lime planks before painting. I have made the gun ports 10mm for now as at that size I can fit the canon barrels through the ports onto the trucks.
Cut away on the half frames I also reduced their hight and the top of the stern post by their own thickness enabling frame 47 to be fitted at the same hight as the middle gun deck.
View from the Stern, the Port sub deck dry fitted. As you can see I have also cut a hatch amid ships and two for the anchor cables. the forward bulkhead has yet to be tidied up before painting ( below decks will be painted off white to mimic the lime wash used to protect the wood and reflect light from the lamps).
Sub decks to be trimmed off when fitted
Frame 47 refitted dry for now
View with Stern castle dry fitted
View along the Lower Gun Deck with the Port sub deck in place looks like I will have to trim a little more off the inner uprights.
View along the middle deck. I have still to trim back frames 28 & 29 and cut the embrasure for the tiller as the steering room was at the after end of the middle deck.
like I said mine is not a standard build.
Thanks again Guys
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#17 Posted : 13 January 2013 17:51:45
BigGrin Very nice work SandyCool
#18 Posted : 13 January 2013 22:47:05
Looking good there Sandy....
court orchard
#19 Posted : 14 January 2013 00:42:53
Glad to see you got there, with the photos, in the end.
Looks a very interesting departure from the standard build, hope to see more photos as you progress.
SandyM
#20 Posted : 10 August 2013 07:53:49
My mods so far
SandyM attached the following image(s):
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
This page was generated in 0.209 seconds.
