9 Pages «<34567>»
MWG build diary of the HMS Victory X - Section Options
#81 Posted : 24 September 2012 17:25:59
ISSUE 127 BUILD
and the parts we use at this stage are used to forme the shot locker and pump well, here they are:-
#82 Posted : 24 September 2012 17:28:08
ISSUE 127 BUILD
Following the instructions I built the item:-
#83 Posted : 24 September 2012 17:36:33
ISSUE 127 BUILD
at the point I deviated from the instructions and changed the lip that goes across the back of the shot locker, from the ply supplied to a piece of walnut see the next photo:-
I intend to cover the pump well and shot locker in 5mm x 1/2mm walnut, It has a grain like scale oak and I will leave it rough looking without sanding.
#84 Posted : 24 September 2012 17:40:50
ISSUE 127 BUILD
Well team thats it for this session, thanks for looking inBigGrin Question and comments welcome.
I will leave you with the photo of what we have achieved this time:-
Regards Mike
#85 Posted : 24 September 2012 18:11:16
Hi Mike,
Nice work, good presentation,coming on well.
Kind Regards Trev.
Gus W
#86 Posted : 24 September 2012 19:13:04
MWG wrote:
Gus W wrote:
MWG wrote:
Gus W wrote:
Are those the Caldercraft cannons Mike?
Hi Gus, I have the made as a kitBigGrin Regards Mike
They look very nice Mike. Cool
I am after some replacements for the Endeavour, so I just wondered if they were the Caldercraft 4 pounders
Hi Gus I have sourced cannons and a 10 spoke ships wheel, in brass etch, size is 24mm ( a better scale size) for the Endeavour because I wanted them for my build PM your email address and I will send Info and prices.
Regards Mike
Thanks Mike, will do.
Currently Building:
Eaglemoss HMB Endeavour
De Agostini Sovereign of the Seas
#87 Posted : 25 September 2012 02:04:06
tf64 wrote:
Hi Mike,
Kind Regards Trev.
Hi Trev thank you, always a pleasure to hear from youBigGrin Regards Mike
Jesus-Belzheim
#88 Posted : 25 September 2012 18:01:22
A very nice work there Mike ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#89 Posted : 26 September 2012 09:16:43
Hi Peter thank you for thatBigGrin Regards Mike
#90 Posted : 26 September 2012 21:16:13
BigGrin Top work as ussual MikeCool
#91 Posted : 27 September 2012 12:23:50
Thanks Andy much appreciatedBigGrin Regards Mike
#92 Posted : 02 October 2012 14:28:30
looking good mike, nice clean build. IanCool
#93 Posted : 02 October 2012 16:38:23
Hi Ian thank youBigGrin Regards Mike
#94 Posted : 03 October 2012 21:05:19
ISSUE 128 BUILD
Hi Team, I have not posted on this build for a while, as many of you will know this is one of my favourite builds with lots of scope for enhancements and modifications, but more about those later.
In this issue the object is to construct the main hull supports, these are made up of dedicated parts, I followed the instructions at this point:-
#95 Posted: : 03 October 2012 21:15:22
ISSUE 128 BUILD
1st MODIFICATION
In the last picture I was not happy with the ends of the ply being on show so I decided to sheath the beems with 5 x 1/2mm walnut I have purchased to second plank the Victory, the grain is the nearest I have seen to simulate oak at this scale.
I cut some pieces and soaked them in hot water then clamped them onto the wood while wet but no adhesive, have a look:-
#96 Posted : 03 October 2012 21:22:47
ISSUE 128 BUILD
The sheathing will dry and the shape will be formed ready for the adhesive, I will show you the result next time.
2nd MODIFICATION
Next I saw from the Antatomy of the ship that a different limber configuration supporting the first deck was needed so I added a beam 3mm x 5mm plus 2 extra 2mm x 5mm stris under it, here it is:-
#97 Posted : 03 October 2012 21:26:19
ISSUE 128 BUILD
More of this 2 nd MOD next time, but I did have to trim the big hull beams to fit at this point:-
#98 Posted : 03 October 2012 21:29:25
ISSUE 128 BUILD
3rd MODIFICATION
I decided to sheath the shot locker and pump well with the same walnut, I am very happy with the result:-
#99 Posted : 03 October 2012 21:35:46
ISSUE 128 BUILD
Well thats all for now, I have not finished this issues build but I thought you would like to see the progress.
thanks for looking inBigGrin as usual if you would like more info on what I am doing with this build do not hesitate to ask or commentCool
I will leave you with the 4th MODIFICATION ---- sheathing the mast base so you do not see the ends of the ply grain,( the sheaths were soaked in hot water first) Regards Mike
#100 Posted : 04 October 2012 10:18:01
ISSUE 128 BUILD
Hi Team I just thought I would post a photo of the planks now that they are dry, you will see how they are shaped ready to glue on top of the ply parts Regards Mike
9 Pages «<34567>»
This page was generated in 0.336 seconds.
