12 Pages «<34567>»
tf64build Options
#81 Posted : 23 September 2012 22:40:45
Hello Andy,
Thank you for looking at my post,I must say that I did enjoy building the ropes and I will be turning some more the best bit to me is that the rope came from Chatham Docks.
Regards Trev.
#82 Posted : 07 November 2012 21:30:08
Hello Shipmates,
Now onto the hull,I have decided to Copper Plate so here are a few pictures of my work so far.
After sanding a coat of PVA.
One Coat of PVA.
2 Coats of grey primer.
Filling Small Cavitys plus sanding.
2 Coats of Tamiya xf dark copper.
Next I will be posting more picture's,this will be spraying the top with my own mix.
Thank you for looking,
Regards Trev.
mark 2
#83 Posted : 07 November 2012 22:25:39
Hi Trev.
I will follow this part quite closely for when i will be doing mine which wont be for a while yet Glare as i have to many builds going on at the mo.
Anyway wanted to say that you are doing a great job on the vic Love Drool BigGrin Cool .
Top work from a top craftsman.
Best regards.
farrabass
#84 Posted : 07 November 2012 23:14:10
Good luck with the tiling Trev.
I have every confidence in you making a very good job of this part of the build.
Steve..
#85 Posted : 08 November 2012 00:59:10
Hi Trev as usual your work is to an excellent standardBigGrin Good stuff.
Regards MikeCool
#86 Posted : 09 November 2012 00:22:24
Hello Shipmates,
Thank you for looking at my post,Mark,Steve,and Mike,and thank you for your comments,tonight I have mixed the paint to spray the top I will post when I have completed and would you believe I am looking forward to starting the copper plating,I am not to sure about the keel,I will start on the sides of the keel, but did they copper the bottom?
Regards Trev.
Hans
#87 Posted : 09 November 2012 09:56:31
Excellent job so far Trev, real top class workmanship.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
Jesus-Belzheim
#88 Posted : 10 November 2012 16:51:14
Looking good trev
Can`t wait for yout first pictures with copperplates BigGrin
I just finisht the waterline, and now I started with the kiel BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#89 Posted : 10 November 2012 17:02:27
Hello Hans,
Thank you for your reply,I am looking forward to seeing your update how's the Vic coming on.
Regards Trev.
#90 Posted : 10 November 2012 17:05:51
Hello Peter,
Thank you for looking at my post,I still wonder when they will arrive.
Regards Trev.
#91 Posted : 14 November 2012 22:09:10
Hi Trevor.
Truley fantastic build. Keep up the good work. And the pictures coming. Looking forward to seeing more. Ian Cool BigGrin
Riggers
#92 Posted : 17 November 2012 11:42:33
Hi Trev
Very nice build ThumpUp.
When I ordered the copper tiles they took well over a month to arrive but were worth the wait.
Cheers
Builds in progress:
DeAgostini HMS Victory
DeAgostini McLaren MP4-23
" If it looks right then it is right "
mark 2
#93 Posted : 17 November 2012 12:24:11
Hi Trev.
Have you got your copper tiles yet.
Best regards.
#94 Posted : 17 November 2012 18:53:59
Hi Trev
Looking great!
Harty was looking into the 'did they copper the bottom' question a little while ago. From his (and others) research the answer was yes they did, and also no they didn't!
It seems the whole of the keel as built into our models was coppered but then the dockyards added a thin sacrificial 'false keel' in plain wood under the actual one which was designed to scrape on the sea bed in shallow water without damaging the copper plates above it. Hope this helps.
Also, does the DeAg copper come in one single pack or two? The Jotika set comes in two packs and their web site recommends opening both packs and mixing the contents otherwise the second bag will have a different degree of surface patina since it will be exposed to the air for a shorter time than the first.
Happy PlateingBigGrin
mark 2
#95 Posted : 17 November 2012 18:58:05
Plymouth57 wrote:
Hi Trev
Looking great!
Hi Plymouth57.
The Deagostini tiles come in one pack.
Best regards.
#96 Posted : 08 December 2012 15:06:33
Hi Trev all looking goodBigGrin Kind regards Mike
#97 Posted : 09 December 2012 00:34:36
Really looking good... look forward to your progress with the tiling...
#98 Posted : 06 January 2013 20:44:03
Hi All,
Update on the Victory,spray painted yellow ochre I used Tamiya Lemon Yellow(x8)plus Desert Yellow(xf59)plus Flat Red XF 7 this I found to make up a good base under coat.
Thank you for looking in.
Regards Trev.
#99 Posted : 06 January 2013 22:27:19
Hello
I have now started copper tiling my Victory I have found that a steady hand is a must and chop up some bits of wood to use as a guide when placing tiles.There is a back and front way to stick them and also you can pick up two copper tiles which are stuck together, but it looks like one.Before you start you need to make sure you are familiar with trimming I used a very sharp pair of scissors I used two types of glue the main glue was Evo-Stik Serious which will give you time to move them around be for they set, but if you need a quick set I used Vitalbond CA Thin cures in 10 Sec. I also found that Blue-Tac on a probe helped me to judge and keep the tile in line. Also what you need is a lot of time, so far I have spent over 170 hours and I haven't finished one side yet. I started this work over a month ago and had to leave all my other models but what a learning curve. I have posted a few pictures to have a look at to give you an idea.
Thanks for viewing my post it may change your mind about copper tiling.
Regards to you all Trev.
#100 Posted : 06 January 2013 23:23:54
Nice work Trev and no it hasn't put me off copper tiling.... just haven't decided if I will tile or not....LOL ... When you see the finished tiled hull then I'm sure you will think all those hours spent will have beenw orth it..... Keep up the good work....
12 Pages «<34567>»
This page was generated in 0.401 seconds.
