32 Pages «<1112131415>»
ARPurchase's build diary of the Akagi Options
#241 Posted : 17 September 2012 18:48:40
BigGrin Thanks Mike your comments as always are appreciatedCool
#242 Posted : 17 September 2012 18:52:22
BigGrin Thanks Yaturo for your kind words as for the blocks i have noted this from your diary and will fix as appropriate
#243 Posted : 19 September 2012 20:15:43
BigGrin Hi All
recieved the portholes so i can crack on with them now,the packs in the pic should be more than enough to do the requirements for the plans provided in the kit but as i have the myuki-kai plans aswell i shall probably be adding more
Yutaro HONMA
#244 Posted : 20 September 2012 01:55:50
Hi Andy!
What a lot of portholes there are! Building the Akagi is my hobby, but I call next three process "practice mortification" of Zen(禅).Blink
1. Planking the flight deck
2. Attaching Jackstays on the hull
3. Making portholes
Have a good practice for your success.Cool
Best Regards,
Yutaro
#245 Posted : 20 September 2012 21:35:45
BigGrin Hi Yaturo
Most of the portholes are in the correct positions apart from a few,i will be ajusting as i place them
#246 Posted : 22 September 2012 20:04:10
BigGrin Hi All
decided to start the painting of the hangar insides still a little touching up to do here and there as painting was never my strongpoint.As always all comments questions are welcome
#247 Posted : 23 September 2012 18:33:34
BigGrin Hi All
Bit more done on her hull,started to add the lower hull portholes the upper portholes will be added later as i suspect theres more work on the upper superstructure to be done.
I started off marking the positions from the plan on masking tape,here im using 40mm wide tape as it covers all the portholes in one strip,the blue line is where the degausing trunking will run il be using plastic strip here like on the Yamato.After all the portholes were marked the tape was transfered to the hull and then a 2mm drill was used to drill them out ,a 1.5 mm drill was used for the smaller port holes.
I have included pictures of the hull with just the drill holes showing as this is how the instructions say to leave them and after that the pics show with the aftermarket portholes attached.I still have the other side to do as yet and as uyssual all questions/comments are welcome
mark 2
#248 Posted : 23 September 2012 19:09:48
Hi Andy.
Just wanted to say wow great build Drool .
Best regards.
#249 Posted : 23 September 2012 19:21:50
BigGrin Hi Mark
Thank you for your kind words ,much appreciated
#250 Posted : 23 September 2012 20:00:17
I bet that was hard going on the eyes Andy, and certainly an improvement over not adding them Cool
#251 Posted : 23 September 2012 21:57:07
BigGrin Thanks Mr T
not so bad on the eyes just time consuming, marking out, transfering to ship then the endless portholesLOL
Ger C
#252 Posted : 23 September 2012 22:25:18
Hi Andy,
You set a high standard for everyone else to follow
#253 Posted : 23 September 2012 22:47:33
Hi Andy,
Your work is always impressive,keep sending.
Regards Trev.
#254 Posted : 23 September 2012 23:05:01
Hi Ger c and Trev
Thank you both for looking in on my build,Ger not trying to set a high standard just trying to show what can be achieved with a little thought and perseverance and we are all capable of achieving better than what we imagine.Trev your support is always apreciated
#255 Posted : 24 September 2012 03:57:46
Hi Andy Top Job, your work on a difficult build is smashingBigGrin Regards Mike
Yutaro HONMA
#256 Posted : 24 September 2012 04:12:25
Hi Andy!
You've done not only practically hard jobs but also mentally hard ones! Laugh I think such hard jobs make your ship more and more great one. I expect your next sending.
Best Regards,
Yutaro
#257 Posted : 24 September 2012 21:19:36
BigGrin Thank you both Mike and Yaturo your comments are always apreciated
Dontshootme
#258 Posted : 25 September 2012 08:48:14
Wow..what a difference that has made to the overall look of the model.How many portholes were there in total as I may do this myself when I get round to starting my build.
#259 Posted : 25 September 2012 23:15:09
BigGrin Hi Dontshootme
If you take a look at page 12 post 130 the porthole count and info you need is listed there m8
Dontshootme
#260 Posted : 26 September 2012 09:00:18
Thanks for that Andy,must have missed that postBlushing ,sometimes I don't get the red "new post" symbolBlink ...can be very annoying.Cursing
Guest (20)
This page was generated in 0.218 seconds.
