 Rank: Pro Groups: Registered
Great build so far , I agree with the others pull out the pins . I second planked my build using Walnut and Lime , I then equally spaced pins along the planks approx every second rib ,Gives of a good result without going over the top on a model of this scale. Happy building Mald
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
shes looking very ship shape mate, i agree with the other remove the pins, i left pins in my chinese junk model and now with more experience it looks bad, wish the forum had been around when i started modelling current builds
Joined: 20/12/2011 Posts: 236 Points: 686 Location: shetland
thank-you all for your input  .I will sit out in the sunshine and pull them out.it will take a while. I read in earlier magazines or the forums that you can leave them in to look more authentic when painted or varnished (rivets),but I thought how do you sand the hull with the pins in  ,`cos metal and wood does not sand the same,must of been putting them back in after sanding or I misread it,anyway they are coming out this weekend. Thanks again
To say nothing of the size of the rivets on a 1:80 scale.
Great job BTW, should sand up nicely.
John
Hi all, I am just about to measure the distance of the last 10 planks needed to finish the hull planking (issue 38).The distance id 52mm on rib 21, would it be advisable to put another plank on to make it 47mm or just work it out from where I am which will be 11 planks. any help would be great. sandnesspeats attached the following image(s):
Although it measures up to be more I never found it a problem since there will always be a slight spacing between the planks no matter how tight you make them. It should come down after a couple of planks are laid. You might find this useful also - Last 10John
Thanks for that I have downloaded the spreadsheet, great help.Here goes the measuring!!!
BTW you may still need some droppers and steelers in there.
John
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Are you painting your model? I decided upfront that I was going to paint, so I added 2 rows of planks next to the keel before starting the measuring. I believe it made the process faster and easier.
Joined: 11/09/2011 Posts: 227 Points: 677 Location: Heidelberg South Africa
LOOKING GOOD! KEEP THE PICS COMING! Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Hi all sorry for not replying,been very busy. I have not decided about paint or varnish yet,just concentrating on getting the hull finished,but probably will paint as I bought them ages ago. Enclosed are some pics just not sure how to proceed. The measurement at the stern is only 20mm and the middle of the keel to plank is 45mm. I have never put a dropper in yet anywhere but it looks like I will have to now,Any advice would be greatly appreciated sandnesspeats attached the following image(s):
A quick look through some members build diaries will throw up some options for you! Darren has produced a graphic in his diary showing how and where to taper the planks to get a snug fit. If painting is going to be your desired finish, then the planking will be covered in paint and will obscure the run of the planks, that will make it easier to blend in some smaller odd shaped filler pieces. Take your time and have a good read at what is on offer. All the best Steve..
Joined: 04/06/2012 Posts: 19 Points: 57 Location: Pretoria (SA)
I agree, wood filler little bit of sanding and paint problem solved. The thing is, if you going to build an another model and you want the planking to be visible, don’t you think it’s a good idée to practice on the Victory while you are busy with the planking. Only a suggestion. Your build looks very good  . Built Albatross, build in 1982 from plans. Hms Bounty, build in 1987 from plans. Duyfken,build in 1991 from plans Oosterland, build in 1998 from plans
In the meantime. HMS Victory (Deagostini) 2011 Building MFV63 fishing trawler from plans. HMS Mayflower (Kit)
Wish list Still planning.
Thanks guys, was trying to find darren to no avail,could you point me in the right direction!,thanks Just don`t want to be stuck on the same thing for ages,gets tedious. but will horse on as they say, I will be happy and relieved when the hull is finished  .I will get there
Hi guys, I am at a tricky bit,the thing is the stern measures 17.6mm,the widest part is 42mm that is about 8 planks,will I have to reduce the very stern plank to just over 2mm instead of 2.5mm. Any advice or pointers would be great  sandnesspeats attached the following image(s):
You need some droppers. The instructions should have already covered these already. Have a look here (scroll down). John
Thanks John,I thought there might have been another way as I have not put any droppers in yet. But looks as if I will have to. Thanks again
Have another read through the instruction to check. It does say you may need to use droppers and/or steelers even on the last 10.
John
Hi all, Would you look at the pictures and advise me what to do next, I am running out of space before I finish the hull.Do I just keep going as I am and sort it out near the finish or do I try and sort it out now. I have been on this for ages and would like to get it finished,(the hull I mean) as usual any help would be great. thanks sandnesspeats attached the following image(s):
