40 Pages «<56789>»
#121 Posted : 20 September 2012 23:20:20
Hi Mike, excellent posts as usual, it's all appreciated. I too would like to pack out the hull with balsa as I think this will aid in the shaping process prior to tackling the planking as well as giving the hull extra strength. Can I ask however, will you be giving us Newbies an idea as to the amount and size of balsa wood we will need to order to do the job and do you know of a place online where it can be ordered....
Now about to tackle issue 3... thanks again...
Hi GD, thank you for your comments, I will be covering the fitting of Balsa infills when the ribs have been fitted, and giving sizes etc.
You are right the Balsa aides the fitting of the planksCool Regards Mike
#122 Posted : 21 September 2012 15:08:18
BALSA INFILLS (BOW PART No 2)
Hi Team, its time for me to start using balsa wood, to strengthen the Bow formers.
Its something I prefer to do (you do not need to)with all my ship builds.
STEP 1 cut the first pieces of Balsa (these are 10mm thick):-
#123 Posted : 21 September 2012 15:14:21
BALSA INFILLS
STEP 2
I now measure and cut two more infills (these are 6 mm thick) I used two pieces of 3 mm thick from some offcuts I had:-
#124 Posted : 21 September 2012 15:23:19
BALSA INFILLS
STEP 3
Please make sure if you decide to do this, you do not fill the centre slot because judgeing by the hole at the middle of part 2 the bow sprit will be fitted here, plus there is a slot at the bottem where we are going to fit another part.
I will add two more infills of 10 mm thick when I have fitted bow formers 12 in another issue.
Well thats all for now,BigGrin Questions and comments welcome, I will leave you with a photo of the balsa roughly shaped at this point.:-
Regards Mike
jonny7england
#125 Posted : 21 September 2012 16:01:27
Good job mike...still have not picked up my balsa packs as yet!! Better get my backside into gear!! Are you just packing the bow and stern sect ions with balsa or are you doing the whole lower hull Mike?
Blink ThumpUp
#126 Posted : 21 September 2012 16:20:46
Hi Jonny, cheers for that, I am going to do the whole lower hull, you know me where ever I can put balsa to make planking easier and more stableBigGrin Regards Mike
Jesus-Belzheim
#127 Posted : 22 September 2012 15:31:17
That looks very good Mike ThumpUp
And I think that I will use the Balsa for my next Ship too
It looks much easier to plank, and to get a better rounding ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#128 Posted : 23 September 2012 00:13:42
Hi Mike,
Great post,I would fill in the hull every time on my models,a very good and worth while tip for members new to this forum,this also helps at the planking stage.
Kind Regards Trev.
#129 Posted : 23 September 2012 00:37:01
Thanks Mike, exactly what I wanted to see... Went out and got balsa today and have packed between the bow formers... quite please with the results so far... Have also decided to attempt my first diary, managed to upload two photo's, quality not great but that will improve.. Just trying to work out how to display the images as a post rather than a download..... Great work as usual Mike....
jonny7england
#130 Posted : 23 September 2012 09:35:55
Hi Mike...I think that packing balsa along the entire length is the way to go on this build, always packed bow and stern but the whole length is going to be a first for me this time around!! Keep up the good work mate!!
Wink ThumpUp
court orchard
#131 Posted : 23 September 2012 11:05:08
Hi Mike,
I've never used Balsa before, but it seems like a good way to go. Not sure my pocket is deep enough (@ the prices in my local shop) or my sanding arm tough enough, to Balsa the whole Hull though. Excellent posts, as usual, thanks for all the food for thought.
Dontshootme
#132 Posted : 23 September 2012 11:05:22
Make your pics 600x450 ish,they will then show up
#133 Posted : 24 September 2012 04:14:31
Hi Peter thank you it is easier to plankBigGrin Regards Mike
#134 Posted : 24 September 2012 04:15:41
tf64 wrote:
Hi Mike,
Kind Regards Trev.
Hi Trev thanks for the positive commentsBigGrin Regards Mike
#135 Posted : 24 September 2012 04:17:27
Hi GD you are doing greatBigGrin Thanks for the nice comments, Regards Mike
#136 Posted : 24 September 2012 04:19:25
Wink ThumpUp
Cheers Jonny I use special files to shape the Balsa, not as hard as you thinkBigGrin Regards Mike
#137 Posted : 24 September 2012 04:22:01
court orchard wrote:
Hi Mike,
Hi Andy, the balsa costs approx £5 1/2 inch x 3 feetBigGrin you need x 2
Regards Mike
court orchard
#138 Posted : 24 September 2012 10:35:02
Hi Mike,
That doesn't sound bad at all for price and quantity, what width is that? The local Shop wanted £5 for a piece 10mm x 500mm x 100mm, and I thought I am going to need a lot of those. I shall look further afield. Thanks for the info.
#139 Posted : 25 September 2012 02:06:28
Hi Andy you my need max 3 we only use the box method when fitting the BalsaBigGrin Regards Mike
court orchard
#140 Posted : 25 September 2012 10:28:21
Hi Mike,
That makes sense, thanks for the reply.
Guest (18)
40 Pages «<56789>»
This page was generated in 0.412 seconds.
