Gandale wrote:Finding your advice and that of Mr T's straight forward and easy to follow....(so far!!). Thanks Mike, can see with your help and the helps of others in this forum, a degree of confidence in this build is slowly surfacing.... Waiting for issue 3 and so far all is going well.... Keep the excellent posts coming, us Newbie's need them all... Hi GD, thank you for, your nice comments  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
jonny7england wrote:Great stuff Mike, as usual, and very informative mate, love it!!  Thanks Jonny for your encourgement  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
StefanDV wrote:Looking great Mike! Definitely a SOTS diary I'll be following. Hi Stefan,thanks for the kind words  I hope you will not be dissapointed  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
tf64 wrote:Hi Mike, Great post thanks for posting well represented.
Kind Regards Trev. Hi Trev, thanks for the comments, praise indeed when I see your modelling skills  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 3 BUILD Hi Team here we are at week three (how time flies) I am keeping it simple once again so all the new members pick up more and more of the build process,(some one said repeatition is the mother of all learning!!!! or--maybe I have just made that up  anyway I think it works. This is what we received:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 3 BUILD And the parts:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike, I think, (When you are young you listen - When you are old you understand) Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
ISSUE 3 BUILD I am only going to use parts 7, 7a, 7b and 11 x 2. Lets deal with 7, 7a and 7b first, so remove all the loose ash using the tools as before again this is not so critical on the outer edges because later on in the build we will be fairing these parts. :- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 3 BUILD Now using our white conti board with the plastic coating ( so the glue does not stick to the board) fix the parts together with adhesive making sure the parts are flat:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 3 BUILD Next up is fitting parts 11 to bulkhead part 2, again trim off all loose ash and using adhesive fix the parts useing a square to test for a true fit on our white board:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 3 BUILD A good idea to keep your parts flat untill you start building the keel, beg steal or borrow a couple of large tiles (the edges are rounded so will not cut your hands) place the parts on the decorative side of the tile, then place the other tile decorative side down and store under the bed or similar. I buy my tiles from B&Q, please have a look:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 3 BUILD Well Team thats all for this week, thanks for watching  Questions and comments are welcome, I will leave you with the parts we have built this week:- Regards MIke MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Cracking suggestion Mike... Plus land up with a sovereign sandwich... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 14/12/2010 Posts: 142 Points: 425 Location: Grantham
Nice work again Mike, and just used your suggestion lol
Craig
Blackspear wrote:Nice work again Mike, and just used your suggestion lol
Craig Hi Craig thank you and I am pleased you found it usefull  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
tf64 wrote:Hi Mike,
Kind Regards Trev. Hi Trev thats a better saying ,thank you  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
jonny7england wrote:Cracking suggestion Mike... Plus land up with a sovereign sandwich... Hi Jonny thanks again, for looking in, we could call it a club sandwich  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 02/09/2012 Posts: 73 Points: 225 Location: York
Great idea Mike. As luck would have it I have some spare old tiles in the garage. Currently Building:
Eaglemoss HMB Endeavour De Agostini Sovereign of the Seas
Hi Mike, excellent posts as usual, it's all appreciated. I too would like to pack out the hull with balsa as I think this will aid in the shaping process prior to tackling the planking as well as giving the hull extra strength. Can I ask however, will you be giving us Newbies an idea as to the amount and size of balsa wood we will need to order to do the job and do you know of a place online where it can be ordered....
Now about to tackle issue 3... thanks again...
Gus W wrote:Great idea Mike. As luck would have it I have some spare old tiles in the garage. Hi Gus thank you, there are always some lying around  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (22)
