40 Pages «<45678>»
#101 Posted : 19 September 2012 10:45:06
Finding your advice and that of Mr T's straight forward and easy to follow....(so far!!). Thanks Mike, can see with your help and the helps of others in this forum, a degree of confidence in this build is slowly surfacing.... Waiting for issue 3 and so far all is going well.... Keep the excellent posts coming, us Newbie's need them all...
Hi GD, thank you for, your nice commentsBigGrin Regards Mike
#102 Posted : 19 September 2012 10:46:29
jonny7england wrote:
Great stuff Mike, as usual, and very informative mate, love it!! Wink ThumpUp
Thanks Jonny for your encourgementBigGrin Regards Mike
#103 Posted : 19 September 2012 12:21:17
StefanDV wrote:
Looking great Mike! Definitely a SOTS diary I'll be following.
Hi Stefan,thanks for the kind wordsBigGrin I hope you will not be dissapointedLove Regards Mike
#104 Posted : 19 September 2012 12:24:16
tf64 wrote:
Hi Mike,
Great post thanks for posting well represented.
Kind Regards Trev.
Hi Trev, thanks for the comments, praise indeed when I see your modelling skillsBigGrin Kind regards Mike
#105 Posted : 19 September 2012 12:46:10
ISSUE 3 BUILD
Hi Team here we are at week three (how time flies)
I am keeping it simple once again so all the new members pick up more and more of the build process,(some one said repeatition is the mother of all learning!!!! or--maybe I have just made that upBlink anyway I think it works.
This is what we received:-
#106 Posted : 19 September 2012 12:48:43
ISSUE 3 BUILD
And the parts:-
#107 Posted : 19 September 2012 12:53:31
Hi Mike,
I think,
(When you are young you listen - When you are old you understand)
Kind Regards Trev.
#108 Posted : 19 September 2012 12:53:35
ISSUE 3 BUILD
I am only going to use parts 7, 7a, 7b and 11 x 2.
Lets deal with 7, 7a and 7b first, so remove all the loose ash using the tools as before again this is not so critical on the outer edges because later on in the build we will be fairing these parts. :-
#109 Posted : 19 September 2012 12:57:47
ISSUE 3 BUILD
Now using our white conti board with the plastic coating ( so the glue does not stick to the board) fix the parts together with adhesive making sure the parts are flat:-
#110 Posted : 19 September 2012 13:01:43
ISSUE 3 BUILD
Next up is fitting parts 11 to bulkhead part 2, again trim off all loose ash and using adhesive fix the parts useing a square to test for a true fit on our white board:-
#111 Posted : 19 September 2012 13:09:07
ISSUE 3 BUILD
A good idea to keep your parts flat untill you start building the keel, beg steal or borrow a couple of large tiles (the edges are rounded so will not cut your hands) place the parts on the decorative side of the tile, then place the other tile decorative side down and store under the bed or similar.
I buy my tiles from B&Q, please have a look:-
#112 Posted : 19 September 2012 13:12:30
ISSUE 3 BUILD
Well Team thats all for this week, thanks for watchingBigGrin Questions and comments are welcome, I will leave you with the parts we have built this week:-
Regards MIke
jonny7england
#113 Posted : 19 September 2012 14:55:48
Cracking suggestion Mike...ThumpUp Plus land up with a sovereign sandwich...Laugh
Blackspear
#114 Posted : 19 September 2012 17:39:20
Nice work again Mike, and just used your suggestion lol
Craig
#115 Posted : 19 September 2012 19:21:00
Craig
Hi Craig thank you and I am pleased you found it usefullBigGrin Kind regards Mike
#116 Posted : 19 September 2012 19:22:13
tf64 wrote:
Hi Mike,
I think,
Kind Regards Trev.
Hi Trev thats a better saying ,thank youCool Regards Mike
#117 Posted : 19 September 2012 19:45:43
Hi Jonny thanks again, for looking in, we could call it a club sandwichLove Regards Mike
Gus W
#118 Posted : 20 September 2012 15:09:07
Great idea Mike. As luck would have it I have some spare old tiles in the garage. BigGrin
Currently Building:
Eaglemoss HMB Endeavour
De Agostini Sovereign of the Seas
#119 Posted : 20 September 2012 19:07:18
Hi Mike, excellent posts as usual, it's all appreciated. I too would like to pack out the hull with balsa as I think this will aid in the shaping process prior to tackling the planking as well as giving the hull extra strength. Can I ask however, will you be giving us Newbies an idea as to the amount and size of balsa wood we will need to order to do the job and do you know of a place online where it can be ordered....
Now about to tackle issue 3... thanks again...
#120 Posted : 20 September 2012 23:16:31
Hi Gus thank you, there are always some lying aroundBigGrin Regards Mike
Guest (10)
40 Pages «<45678>»
This page was generated in 0.381 seconds.
