20 Pages «<1516171819>»
Karl's H.M.V Endevour.Part work's with Eaglemoss. Options
#321 Posted : 01 September 2012 13:07:21
that's the foreyards rigged and that's all for this week.
saintsman123
#322 Posted : 01 September 2012 17:10:19
its coming along nicely karlBigGrin
its a pity about the metal windows, they take away from the great work you have done.
Come on you Jimmies
#323 Posted : 07 September 2012 14:49:45
week 85,foremast to complete and add the rigging blocks.
#324 Posted : 07 September 2012 14:58:39
I have to add that although you get a 1/1 plan of the foremast,the plan is in no way complete,measurements are scarce to say the least,and the instruction are complicated and fuzzy.a great shame is we have loads of members who are doing this build and NOT putting up a build diaries.
saintsman123
#325 Posted : 07 September 2012 15:39:33
with your experience you should manage to do without plans karl, in fact i'm sure you could rig a ship in a dark room with a blindfold on.BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
seriously though it's a pain when you don't get all the required info to build a kit, i have come across this with the delprado cutty sark and bounty, and other a/l kits, and even trawling through the internet does not get you the info you need.Cursing
Come on you Jimmies
#326 Posted : 07 September 2012 15:43:59
cheers bob,check your shoe laces ...........he he (I tied them) shushhhhhhhhhhhh
#327 Posted : 17 September 2012 10:42:47
week 86. first the channel chains,looking at the mag all looks straight enough, coil of 1mm. brass wire(soft).this needs straightening,an old trick is this,take one pair of nose pliers and coil it round end,undo coil brass wire,rest first pliers on floor (still attached)place right foot on pliers and with a second pair of nose pliers attach at other end,you stretch as hard as you can,this beleave it or not will straighten the wire. snip off the ends and you have a straight piece of wire.the first pic. is done by using round nose pliers.the mag says cut the wire at 60mm.far to long,cut at 50mm.with the 5mm. deadeye in place mark 20mm.down from deadeye and do a 90degree bend.
the next job is to tie a .8mm thread to the fighting top,(first platform)this is to position the channel chains,they should be fixed at an angle to the shroud.put 1st deadeye in first hole in the channel,using the thread mark for a 1mm. drilling hole.position the chain and superglue,I used thick superglue.
more to come later..............
Gus W
#328 Posted : 17 September 2012 11:16:24
Good tip to straighten the wire. Cheers Karl. BigGrin
Currently Building:
Eaglemoss HMB Endeavour
De Agostini Sovereign of the Seas
#329 Posted : 17 September 2012 15:57:31
the steering is straightforward enough,I made up all the eyebolts and blocks first then fitted them with the main rope threaded as I went round the deck.
#330 Posted : 17 September 2012 16:07:19
added the brass nails under the chains.
#331 Posted : 24 September 2012 14:58:36
week 87.and a fair amount to do this week.the main masts,and yards,the ships boat supports,rigging the anchors,and rigging main masts and yards.
and that's it for another week.please comment,all welcome,newbees any questions????
Son of Bulwark
#332 Posted : 24 September 2012 15:21:59
Hi Karl! Cool
It's looking great, you have done a lot since the last time I looked. I haven't been able to read all the posts I would like, but your ship is well detailed and is a credit to you Karl. I look forward to seeing her with the masts on.
Darron
#333 Posted : 24 September 2012 17:23:49
many thanks for the comments,won't be long before the masts go up.
Gus W
#334 Posted : 24 September 2012 17:41:27
Coming along nicely Karl. The masts are the bit I am not looking forward to, but will have to start on them soon.
Currently Building:
#335 Posted : 24 September 2012 17:57:07
the masts are ok to do,it's the yards that are a nightmare,the amount of blocks is ridiculous,on the main yard their are 20 blocks plus the parrel beads and stirups to do. also the stun'sail booms and fittings.
jonny7england
#336 Posted : 24 September 2012 18:04:49
Wow!!! She really looks great Mate!! Love it!! Love
Gus W
#337 Posted : 24 September 2012 19:21:46
Yes, it all looks tricky, especially for a newbie to ship models. The pictures just don't give enough detail, so it is going to be a frustrating task I feel.
Currently Building:
IAN
#338 Posted : 24 September 2012 20:36:09
Hi Karl....
The Endeavour is looking great, keep the good work up and hope to see the masts taking shape.
Best regards,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
#339 Posted : 24 September 2012 23:14:23
thanks gus,jonny,and ian.I suspect it's the mizzen next,then the deadeyes and channel chains next.
#340 Posted : 24 September 2012 23:19:03
Does it come with a stand?
