Hi All, I am back with a few more pictures,first I found cutting out the parts from the fret was easy,just a light sand around the frame done,assembling the keel and keelson it is important that the two parts are perfectly aligned then on to the first and second rib at this stage I found the spacers suppiled a must to stop twisting,again very important to let it all dry.I found that by feeding the dowel through the lowest holes and adding more spacers keep it all straight. One to watch is fitting 3e 4c you can fit them the wrong way round,as you will see in my post picture,I must say that at this stage I found it a bit awkward to do you need three hands.The last part was to add the discarded part of fret and use as a brace to keep it all straight.         This small part you need to get the correct way round.  Old piece of fret to brace. Thanks for your time Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
all looking good trev. i had no plans to subscribe to this until i saw some better pictures, as the ones on the flyer really made it look quite cheap. however i went into my newsagents the other day and lo and behold they had 4 issues of the series put away under my name. i did not ask for them to carry on after issue 120, but when i saw these 4 poor lonely magazines i just had to give them a new home. looking at yours and tomicks diary the early basic structure looks rather fragile, so i think i'll wait a while before starting so i can get something good and solid built in a short time, as dogs and kids did not work well in the early days of my victory build. Come on you Jimmies
Yes fragile until the outer/inner hull planking is added, and then the framework firms up rather well.
Its certainly an interesting and intriguing build
Hello Shipmates, Update on progress so far.     Thanks for your time. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Coming on well Trev
Hi Trev your build is spot on, I have the dimensions of the Mast enhancement  , if you are intereted, what is the width Ht and length of her please? Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
MrT, Thank you for looking at my new build. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Mike, As promised dimensions h/w,as you know builds are not always the same and can vary a bit but I have built my Cross Section to the spacers provide with the build I hope this will help.  WIDTH 222mm  WIDTH 222mm to the outer planks.  LT 91mm  LT 91mm  HT 180mm this was taken from the cutout on the Keelson.I hope this all helps. Kind Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks Trev you are a star  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Shipmates, Update progress so far.  This picture shows 3 strips of 2x5mm wood each side of keelson.  Continuing planking using 1.5 strips.  Hold planking up to issue 125 now for sanding. Regards to you all Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hello all, This is my most recent post,Constructing the Mast Step and Pump House all dry fit. 1st Picture shows the sanding the Keelson to fit the Mast Step. 2nd Picture shows Dry fit the Mast Step to the Keelson. 3rd Picture shows Dry fit also shows Masking Tape number 8 rib and number 2 rib. 4th Picture shows Pump House and Shot Lockers assembly. 5th Picture shows again Pump House and Shot Lockers. 6th Picture shows Mast Step and Pump House. 7th Picture shows Pump House in Place Dry fit. 8th Picture This completes the basic construction so far. Thank you for taking the time to look at my build,and may be you will start your own some time. Regards Trev.         Thank you Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
great work trev. Come on you Jimmies
very nice indeed,very classy. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi Trev, your work is outstanding  Thank you for sharing regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Top notch looks very good. Just a shame the SOTS is out at the moment as after seeing this build I would have been very tempted to have a go at it. But I just dont have the funds to stretch to both of them. Very nicely presented build diary as well Steve..
Hi Shipmates, Thank you for your comments,Saintsman,Kari MGW.and Farrabass, received Issue 128 lot's of bits to play with,will post soon Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 nice work as ussual Trev Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Master at work. Well done Trev, she looks grand. Nice clean build. I'm sure your personal touches will be coming through soon. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hello Hans, Thank you for replying and taking the time to look at my work,I am finding this project so intresting to build and with the knowledge I have gained from building the Victory and all my friends on this forum I find myself looking for the next Issue. With thanks again. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hello Shipmates, I have found time this week to cover the Pump Well with the Oak supplied,due to the thin Oak I found it a bit tricky but I am pleased with the finish,press on with the lids. Regards Trev.  Thank you for your time. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
