anchor Options
colin
#1 Posted : 04 May 2010 20:54:02
Hi,i am new to all this so could anyone tell me if the wood stock of the anchor was painted same as cannons in yellow ochre,Thanks.
#2 Posted : 04 May 2010 23:37:27
The anchore is actualy two different blacks. The timber parts are a flat dull black and the iron a slightly more satin finish. If you look for admiral paints on the internet they have a metal black and flat black that are perfect. see my anchor build in 'first wooden ship build'
ronald305
#3 Posted : 03 December 2018 18:29:01
sorry to barge in Jase
but I thought the timber on the anchors where a varnish brown or something also would you know the size of the hole on the metal part because the manufacture did not punch out the hole all the way there is a tiny piece of metal
protuding out of the other side and would like to drill out the hole correctly thank you
Ronald
z8000783
#4 Posted : 03 December 2018 18:31:40
Groups: Unapproved
ronald305
#5 Posted : 03 December 2018 18:37:32
yep you're right I went to look for my self before you replied thank you
but I still need to know the size of the hole for ring
Ronald
GilShapley
#6 Posted : 03 December 2018 19:28:04
Here is a picture I took of the Victory when I was in Portsmouth showing the Anchors
Hope this will help
Current Build:-
#7 Posted : 03 December 2018 19:29:19
BigGrin Hi Ronald if you measure the ring that goes through the hole the hole just needs to be slightly bigger. Start with a small drill and slowly get bigger while checking the fit .
Hope this helps
Martyn
ronald305
#8 Posted : 03 December 2018 20:42:27
ok thanks Martyn
Ronald
ronald305
#9 Posted : 13 December 2018 18:05:54
Since we are on the subject of anchors I was wondering would it be acturate and ok if I put two bands on the loose ends of the moreing lines I saw someone do it on a victory build post thank you
Ronald
#10 Posted : 13 December 2018 19:06:16
Ronald
Down to your own personal choice on this one Ronald.....
ronald305
#11 Posted : 13 December 2018 19:27:12
ok cool thanks Alan
Ronald
