3 Pages <123
What do i do with the colour problem ? Options
andylangtree
#41 Posted : 08 September 2012 00:50:03
karl1113 wrote:
hi andy,weither you like it or not this so called chesnut has reared it;s ugly head again although somewhat muted.have you ever built a model (any model) that was p repainted? I know I havn't. and the quality to me is 1st.class.I have not paid £600 for a car before so does that qualify as a prepainted job?I don't know,all I know is,bring on more!!!of the same.admin and de-ag have said the fix is to be done,and if you can't put on a bit of varnish on,pack it in.and go back to ships,and dabble with the paintwork on them.I have looked and looked at the paint on my car,and believe it or not I can only see a slight difference in strong daylight. I must stress strongly this is my opinion,and please please put this subject to bed.end of.
Bit out of line dont you think. I asked a simple question and mentioned my concerns over this build and really dont need you to tell me what to do. This is supposed to be a forum that people can ask questions and get help from people with more experience and not to be told forget it and build ships cause there better at it.
andylangtree
#42 Posted : 08 September 2012 00:51:55
[quote=Tomick]Hi Andy, I'm sure you'll be able to manage glossing should the need arise.
As for decal setting solutions, the use and application is noted in the magazine and has been repeated numerous times in McLaren decal discussions, and the process is also noted in my build diary.
Here's a link to the topic..
http://forum.model-space...aspx?g=posts&t=4225[/quote]
Thankyou Mr T
#43 Posted : 08 September 2012 00:55:45
No problem Andy, I seem to recall that someone also posted up a YouTube clip showing the process but I've not located it yet
andylangtree
#44 Posted : 08 September 2012 01:06:16
Please can you post it when you find it, thankyou again
SennaMentalMe
#45 Posted : 08 September 2012 02:30:06
Hello Andy,
If you need help with applying decals and using Micro-Sol and Micro-Set then try this:
http://www.modelcartips....ecals-and-markings.html
And this:
http://www.modelcartips.com/carbon-fiber.html
Hope that helps?
Kev.BigGrin
Stupot
#46 Posted : 08 September 2012 06:36:08
Hi Andy, i know what it's like trying to learn model building skills.The learning curve can sometimes be pretty steep.I've been model building for 15 years, building cars & planes & i'm constantly learning.It look quite a few models & alot of patience just to feel like i was getting any better at it.Decals are apart of model building that alot of people are abit nervous about.The best thing to do is start with the smaller ones & get confidence moving them around on the model & then try the bigger ones.Just watched the above link & it's all good.I use Revell Decal Softner, it just makes them go on abit easier.Practice makes perfect so keep at it.Stuart.
saintsman123
#47 Posted : 08 September 2012 12:20:51
hi andy, i think you were the wrong person at the wrong time for karl, i get the feeling he is a bit like me and fed up with the colour subject.
i think karl only read the first part and did not realise you were asking for some advise about how to go about applying the gloss finish.
don't give up on your model, there are always some daunting bits with models of this complexity. i remember there was a stage of the victory build where we had to take a razor saw to it and saw off some of the sides we had so carefully put on, i waited over a month before i could build up the courage to take a saw to my model.
Come on you Jimmies
#48 Posted : 08 September 2012 13:03:56
hi andy,first off an apology is in order here,I do apologise most sincerely
and I got completely the wrong end of the stick.I thought others were giving you arrows to fire,and did not realise you were asking for help.when I undertook the f1 build I thought we were going to have to paint it,and was most surprised and pleased when it was already done.once again sorry and hope you don't hold it against me.good luck.
#49 Posted : 08 September 2012 13:26:30
Good to see swift reparation. Its very easy in a forum to get the wrong jist.
Thanks for posting the links Kev, exactly what I had in mind Cool
andylangtree
#50 Posted : 08 September 2012 19:54:58
No problem Karl and good luck with your build. Thanks for the links and replies.
#51 Posted : 13 September 2012 20:51:01
only1ianuk wrote:
A Question for Tomick/Admin,
Are we going to have instructions on clear coating like the Japanese had in their last issue?
Thanks
Ian
Hi Ian,
Admin should be posting something up about this tomorrow.
only1ianuk
#52 Posted : 13 September 2012 21:23:48
Thanks
Ian
Hi Ian,
Cheers Tomick!
3 Pages <123
This page was generated in 0.129 seconds.
