Pins Options
Uagen
#1 Posted : 07 September 2012 12:46:22
Rank: Newbie
Hi,
I'm currently at issue 18 of the Victory build. It mentions to 'pin' parts to the frame using the pinning tool ( recieved, thank you ) but I do not have any 'pins'.
Question is.. Do I supply my own pins for the model and if so what type/size of pin is used. Would hate to use wrong ones this early in a build for the whole lot to come toppling down later in the build.
Thanks in advance
Daz
( after 7 months still having to recreate this user everytime I come to this forum Confused )
#2 Posted : 07 September 2012 13:49:56
Pins where supplied in issue 17, which you also use in issue 18
I have looked at your settings and can see no reason why you need to recreate your user name each time you enter the forum, other than to enter the forum you must enter your user name and password unless it has been saved, which is done via the "remember me" tick box in the sign in screen.
Uagen
#3 Posted : 07 September 2012 13:57:20
Rank: Newbie
Hi,
No pins recieved with any issue. Didn't realise they were supposed to be supplied as I already raised a customer support as no cannons have been supplied with any issue since issue 1 . Aparently these have been sent out now, that was on 15th August and not seen any as yet.
So will I have to raise a further customer service request for missing pins too ?
THanks for the very quick response though, much appreciated.
Daz
#4 Posted : 07 September 2012 14:27:51
Hi Daz,
Correct, anything that you are missing or damaged you will need to ask for. My diary build generally shows what is contained within each issue.
http://forum.model-space...=topics&f=17&p=2
Jesus-Belzheim
#5 Posted : 07 September 2012 14:29:49
Hi Daz
The Pins will come with Issue 20 BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
john Ralph
#6 Posted : 07 September 2012 14:48:32
Hi Daz- you will probably be sick of seeing pins by the end of it, they seem to arrive and then multiply! Laugh
farrabass
#7 Posted : 07 September 2012 15:03:10
Get ready for a pin overload, they arrive by the bucket load at times. I haven't physically counted how many I have left, but, it is certainly in the many hudreds!!
Steve..
Uagen
#8 Posted : 07 September 2012 15:32:58
Rank: Newbie
Ha, well thanks all, I'll await the next installments to see the pins. Will have quite a bit to do so looking forwards.
Hope the canons arrive too, will be something to sink some time into instead of all the DIY. If I sit down for more than a couple of mins she'll find something for me todo; roll on the pins :)
Daz
daffy09
#9 Posted : 07 September 2012 18:23:54
Hi Uagen,
If you want some pins, I have hundreds left over from the build, so just PM me with your details and I'll pop some in the post for you.
Oh! and a warm welcome to the forum - you'll get lots of help hereBigGrin
Happy building
David
