Transfer of images from plans to build Options
#1 Posted : 06 September 2012 16:35:08
BigGrin Hi All
Some times you will need to tranfer a downloaded part of a plan or image onto the wooden part you are dealing with on your build.There are several ways to do this ,the old tracing paper method,guestimation or the hot iron transfer method.I didnt invent this idea myself but was told about it by a fellow modeler years ago.
Its a very easy and quick way to transfer images and goes as following,borrow the wifes pride and joy[iron to me and you] and set it to hot or high,then cut out the paper image you need and position it in place on the part you want it transfered too.Some tape to keep it in position is also a good idea.Then when your happy with its position run the iron over the paper once or twice,this should transfer the image onto the part you are dealing with.
I have attached some images from my Yamato diary to ilistrate this method
#2 Posted : 06 September 2012 17:02:32
That is very interesting did not know you could do that thanks for sharing!! BigGrin
philjaps1
#3 Posted : 06 September 2012 19:09:38
Top tip mate,
ThumpUp
saintsman123
#4 Posted : 06 September 2012 20:29:55
thats very similar to what i do every day, only instead of an iron i use my hot foil press.
its certainly a good tip andy.
Come on you Jimmies
Ger C
#5 Posted : 12 September 2012 02:07:50
Hi Andy,
thanks for the tip but I have a questionConfused ,
if you place the paper (ink side down) will you not get a mirror image?Flapper
please advise,
thanks in advance
Dontshootme
#6 Posted : 12 September 2012 09:17:55
i would imagine you use image for right side on the left & vice versa so that the images are against the surface.
Ger C
#7 Posted : 12 September 2012 18:40:43
Hi Rob,
I thought of that but what if the plans are for details on only one side?
Dontshootme
#8 Posted : 12 September 2012 18:52:08
Scan the image & flip it using editing software then print...voila... reverse image.
saintsman123
#9 Posted : 12 September 2012 22:55:20
check in print preferences/properties, you should be able to select print mirror, that way it avoids other software.
Come on you Jimmies
#10 Posted : 13 September 2012 01:13:51
BigGrin Hi sorry i didnt answer but its been a bit busy workwise,the Yamato image used is a view from underneath so just lining up the edges on the wood is fine.If this method is used from plan's to copy hull formers/parts and your woried about a mirror image just turn it over after you cut it out simplesLOL
This page was generated in 0.122 seconds.
