8 Pages «<5678>
Harty,s Royal Caroline new build Options
#121 Posted : 06 September 2012 15:46:23
BigGrin She,s certainly starting to look the partCool
saintsman123
#122 Posted : 06 September 2012 16:01:16
great work there harty.
i have never built a panart kit before and was wondering how good or bad the instructions are, especially for the rigging. i've found in the past, especially with a/l kits that all you get are some very basic instructions with rigging plans that make almost no sense.
Come on you Jimmies
harty
#123 Posted : 06 September 2012 16:30:28
Everything you have heard is true saintsman. There are few laser cut pieces and you have to make a lot from scratch. The rigging plan is one sheet so a basic knowledge of roughly how everything goes is essential or something you can look at and copy. Even at this stage I have made a couple of changes otherwise it looks too basic. Go back to page 1 of this build and look at the parts supplied, it will give you a better idea.
harty
#124 Posted : 12 September 2012 22:24:42
Finally got the matierials to build the front end beak. Decided to do it in 1mm plastic rod and then enhance it up a bit. This is as far as I have got with it. It comes in a bit fiddly also, but it should,nt look too bad when finished and paintedBigGrin .
harty
#125 Posted : 12 September 2012 22:25:44
saintsman123
#126 Posted : 12 September 2012 22:35:37
i'm not surprised that you have used plastic, it can be really frustrating trying to line up wooden parts on the beakhead, no matter that every detail
looks and measures the same on both side, no matter what the wood never seems to line up the way you want.
keep up the good work
Come on you Jimmies
farrabass
#127 Posted : 13 September 2012 00:11:41
Very good use of the plastic. I too keep a supply of plastic strip and micro rod, it has oodles of uses and conforms to oblique angles quite readily, and of course it glues to itself very easily so its good for building parts in bias.
Your build is looking spot on at the moment 10/10.
Steve..
catman275
#128 Posted : 13 September 2012 00:33:16
Hello Harty,
Your build is looking good,
I will try to remember about the plastic rod when I get to this stage in six or seven months time.
Due to family commitments, work and decorating I am only managing one sometimes two planks a day.
cheers Peter
completed..... Endeavour Longboat, San Francisco 2, Virginia 1819
building Royal Caroline
harty
#129 Posted : 14 September 2012 02:58:54
Thanks for the comments guys, I have been toiling away at this beakhead and it is just about done now. Just the paint and some rigging. Here is how she looks at the minuteBigGrin .
harty
#130 Posted : 14 September 2012 02:59:59
harty
#131 Posted : 14 September 2012 17:34:02
Paint scheme done.
zebedeee
#132 Posted : 14 September 2012 19:33:59
BigGrin posh looking ship there with all the bling etc
Cool cracking build, a credit to you
#133 Posted : 14 September 2012 19:48:56
BigGrin Nicely done with the plastic as when its painted up you cant tell the diffrence,shame its not available in several shades of wood coloursLOL
#134 Posted : 14 September 2012 20:36:34
Hi Harty, she is coming onBigGrin Regards Mike
harty
#135 Posted : 15 September 2012 02:24:35
Thanks guys, I reckon the plastic was worth it in the end. Got some rigging on it now but not quite finished. I want to fit the spar and the anchor ropes and then I will post some more picsBigGrin .
farrabass
#136 Posted : 15 September 2012 14:54:05
Perfect, the plastic has done a splendid service.
Steve..
harty
#137 Posted : 15 September 2012 17:58:39
Here it is then ,one anchor on and the spar fitted. Also added a couple of extras just to make it look busyBigGrin Laugh .
harty
#138 Posted : 15 September 2012 17:59:50
harty
#139 Posted : 15 September 2012 18:03:13
Glad everyone likes the plastic, it done the job well. Could put that down to a modelling hints and tips I supposeLaugh Laugh . No but seriously if in doubt get the plastic outBigGrin Laugh .
petpole
#140 Posted : 16 September 2012 16:38:59
Never thought about using plastic on a ship but after looking at your build you can get some great detail in the construction, great build. best wishes peter
Drool Drool Drool Drool
8 Pages «<5678>
This page was generated in 0.391 seconds.
