great copperwork stefan Come on you Jimmies
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Thanks lads! 2 rows of stealers added at the stern. Not sure how the rear most part of the keel is finished off. Is it also tiled?  Some more filler pieces added to the bow  And some more tiles added to the hull
Good work with the tiles. I did tile the stern post but it is completely obscured with the rudder, you already have a copper painted surface there. You may need to repaint the copper after finishing all the tiles as some glue will sneak its way around there, if you decide to tile that area all the glue will be covered in tiles! Your choice, Steve..
Don't try and bend the tiles around the stern post, do it the same as the keel!!
 Rank: Amateur Level 1  Groups: Registered
Joined: 19/03/2012 Posts: 34 Points: 95 Location: Manchester
Hi stefan great job you are doing.I tiled the rear most part of the keel because when I fitted the rudder there was at least a 2mm gap(but every build is a bit different),you can just see the back only at close inspection though .All I did was file the tiles that wear protruding flat then glued a row of tiles down to the waterline didn't take that long.Like farrabass said its up to you.
 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 22/07/2012 Posts: 69 Points: 144 Location: Belgium
Love your work Stefan, keep going like this!!
Thanks Gents. I think I'll tile the back section in the way you recommend. Hope to have some more pictures tomorrow.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Hi Stefan It`s looking better and better, great job
Very neat tiling! Looking beautiful. Greetings, Walter
Joined: 08/02/2012 Posts: 61 Points: 186 Location: N. Wales
Same here Stefan. A great tiling job; and those stealers have been fitted very well. Nice tight fit and neat. Mal. Mal.
Built:
Caldercraft - HM Cutter Sherbourne.
Some more pictures as promised. Sorry about the lighting.
Hi Stefan, OUTSTANDING!!!!!  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Steffan. Someones been busy. Looks stunning, keep up the good work Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Mike & Ian! Almost finished with the Starboard side. All the filler pieces on the bow fitted. Here is a shot of the final row of filler pieces required where the tiles meet the waterline.  All the full tiles at the stern have also been fitted, only the stealer fillers remaining. (The white spot is where a tile had to be removed)  Now to repeat the process on the port side.
Looking great sofar Stefan
Looking great sofar Stefan Sorry I posted 2 times
Thanks Peter! Thanks Peter!  Over the last 2 evenings:  Up to row 9 on the port side. I need more super-glue gel to progress the bow and the stern
Joined: 20/03/2010 Posts: 219 Points: 585 Location: Faversham
Hello mate, very impressive work, nice and clean. Keep those pics comming. Jay _____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
Nearly there, looking very proffesional. Steve..
Thanks lads! As it was a long weekend, there was a bit of time to spend on tiling: 21 Sep: laid down all the full tiles on the port side bow, and and some rows on the side   23 Sep: Some more rows on the port side:  24 Sep: All the rows consisting of full tiles before the twisty sections on the stern:
Looking great, a labour of love, my friend, a labour of love. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Guest (6)
