32 Pages «<1011121314>»
ARPurchase's build diary of the Akagi Options
Yutaro HONMA
#221 Posted : 29 August 2012 04:31:57
Hi Andy!
I'm very glad to see your satisfactory building of the Akagi model.LOL
I have noticed that your lift has 4 free wires. I guess DeAGOSTINI Uk does not also explain how to handle them as DeAGOSTINI Japan did not. Since explanations from the DeAGOSTINI Japan were (are?) doubtful for me, I also left the 4 wires free for several period as shown in a attached picture as you did.Cool
But I found there were no severe pit falls about these 4 wires. I attached the wires at proper positions.
Best Regards,
Yutaro
#222 Posted : 29 August 2012 19:18:32
BigGrin Hi Yaturo
The build instructions say to cut these wires off at the top wheel but i knew these wires were where the lift is attached so i left them uncut for that reason.As for the enjoyment of the build all i will say is she is certainly a chalenge in parts
#223 Posted : 02 September 2012 20:31:12
BigGrin Hi All
Not much happening as im waiting for this months lift parts before i can resume the build on the hangars,but i added the bilge keels for something to do the screws and rudders will be added at the end of the build. As usssual all questions/comments are welcome
Ger C
#224 Posted : 02 September 2012 23:29:16
Hi Andy,
looking good as always
#225 Posted : 02 September 2012 23:34:53
BigGrin Thanks Ger CCool
Yutaro HONMA
#226 Posted : 04 September 2012 02:55:29
Hi Andy
The hull and bilge keels look beautiful. I guess the painting process is closing to your Akagi. I'm waiting for next photos.
Best Regards,
Yutaro
#227 Posted : 14 September 2012 19:57:57
BigGrin Thank you Yaturo
Still have loads to do on the hangars yet
#228 Posted : 14 September 2012 20:33:26
Hi Andy really great work, love it BigGrin Regards Mike
#229 Posted : 15 September 2012 00:07:06
BigGrin Thanks MikeCool
#230 Posted : 16 September 2012 10:37:28
BigGrin Hi All
heres a couple of pics of the last stern lift]excuse the wet paint]Blink .This is the smallest and most chalenging lift to fit everything into,as space is at a premium.I had to do a fair amount of fettling on the motor components bases to get everything to fit,but as you can see it is possible to get it in with a little bit of thought.
If like me you decide to use Amati's portholes to enhance your build the 1.5 porthole count is 66 and the 2mm is 496, so you will need 1 pack of 1.5 mm[aprox 100 per pack for 1.5 and 2.0 mm]and 5 packs of the 2mm portholes,i obtained mine from CMB but this will not be cheap option as you wont see much change out of £46.00 with post and packing.
I can now continue with the fitting of the stern hangars and then some serious painting of the internal walls/floor.After that theres the portholes to add and the deguasing cable,i will be using plastic strip for this again as in my Yamato build and then more painting of the external hull.As always all questions/comments are welcome
simon walton
#231 Posted : 16 September 2012 14:24:11
Rank: Newbie
Hi could someone please send me a link for the build insructions for the second instalment to the akagi
Ger C
#232 Posted : 16 September 2012 14:29:18
Excellent as always
Ger C
#233 Posted : 16 September 2012 14:37:56
you should have received an email stating that it was available, if not then your best option is to contact cs
#234 Posted : 16 September 2012 14:49:43
BigGrin Thanks Ger C for your kind words, Simon if you were able to download the 1st set of instructions use that e-mail that you were sent at the time to renter the download page,if it still says Akagi 1 only then do this, in bottom left of download page there is a log out button[very easy to miss] log out using this then reenter your passcode and the 2nd set of instructions should then appear ready for download.Hope this helps
#235 Posted : 16 September 2012 21:39:55
BigGrin Hi All
More progress to post ,i have now finished the 3 lift platforms just a bit more paint to add here.The hangars are all now in place and some of the cappings have been added some filler will be needed in places to tidy things up,next i will be busy painting up the hanger internal walls/decks then its the portholes to add.As ussual all comments and questions are welcome
#236 Posted : 16 September 2012 22:24:06
Hello Andy,
Watching with intrest looking good Andy.
Regards Trev.
saintsman123
#237 Posted : 16 September 2012 22:41:06
looking good andy, i've got 8 packs now so will be starting quite soon.
Come on you Jimmies
#238 Posted : 16 September 2012 23:30:49
BigGrin Thanks for looking in Trev your comments are apreciated and Saintsman thanks also, so when are we to see your build diary m8LOL
#239 Posted : 17 September 2012 00:13:43
Hi Andy, I love this buildBigGrin I know its not easy but you are doing a great jobLove Regards Mike
Yutaro HONMA
#240 Posted : 17 September 2012 12:19:01
Hi Andy!
Your work of lifts were very fine. Motors, gears and wires seems realistic!Love
By the way, as I wrote in another topic, DeAGOSTINI Japan closed this part work without showing us how to fix the floors of the lifts. I recommend you to make some kinds of stoppers for the floors.Cool
Best Regards,
Yutaro
This page was generated in 0.300 seconds.
