Dummy Cannons Options
riff-raff
#1 Posted : 25 August 2012 08:23:02
Hi Guys.
I have skipped ahead of the magazine slightly and I am thinking about placing the first set of dummy cannons but I am unsure where they fit.
Could someone enlighten me please as to which level they go on?
Thanks
Built:
Son of Bulwark
#2 Posted : 25 August 2012 10:36:02
Hi riff-raff! Cool
There are two types of dummy cannons the large 32 pounders fit in the lower deck gun ports and the smaller 12 pounders that are used in the rest of the gun ports.
Hope this helps!
Darron
z8000783
#3 Posted : 25 August 2012 11:10:14
Groups: Unapproved
Shouldn't the middle deck be 24's?
John
Son of Bulwark
#4 Posted : 25 August 2012 12:40:16
Yes John!Cool
Middle deck guns should be 24 pounders but DeAGOSTINI only used 12 pounders and 32 pounders in this build. I think Lord Nelson would've had something to say about that!LOL LOL LOL
Darron
#5 Posted : 25 August 2012 12:56:10
Hi Riff raff,
I was fortunate to source 24 pounders for my buildBigGrin as the bore of the barrel is different. some members I believe drilled out the barrels of the guns supplied to simulate the 24 pounderCool Regards Mike
riff-raff
#6 Posted : 25 August 2012 15:29:43
Just what I like about this forum. The simplest questions can sometimes result in the greatest of debates!!
I am sure Nelson would not be pleased with Diag messing with his ships armament.
Thanks for the answers guys. Just out of curiosity where did you find your 24 pounders Mike?
Riff-Raff
Built:
#7 Posted : 09 September 2012 17:47:50
Riff-Raff
Hi Riff-Raff
I am having them madeBigGrin Regards Mike
farrabass
#8 Posted : 23 September 2012 12:17:10
Riff-Raff
If I may make a suggestion? CMB carry a stock of dummy cannons. If you look under Amati ship fittings (weaponry) they have a selection of dummy barrels in a bronze finish, they are avaiable in various sizes and prices, I have just ordered 24 of the 17mm type at 30p each.
They will need a slight amount of modification to the muzzle end but nothing too severe, I just think they are a slighly better alternative than using the supplied 12 pounders in place of 24 pounders.
Just a thought, Steve..BigGrin
GilShapley
#9 Posted : 23 September 2012 17:58:41
Is the only difference between the 12 and 24 pounders the size of the bore????
I have been making barrell plugs (Painted red) for the exisiting deck guns and intend to do the same for the dummy barrels.
Will this cover up the difference I wonder
Current Build:-
daffy09
#10 Posted : 23 September 2012 19:26:36
Hi Gil
In my humble opinion as a newcomer to wooden ship modelling, the idea you have in fitting barrel plugs to the twelve pounders on the middle gun deck might work if they were made larger than the diameter of the barrel itself (as your photo shows).
If you wanted to make your build as authentic as possible though, the barrel plugs on the ship itself are as far as I know, only just a little bit larger than the bore of the cannon and wouldn't overlap the outside diameter of the barrel.
A good illustration is found in the book "HMS Victory - First Rate 1765" by Jonathan Eastland & Iain Ballantyne, page 46, top photo.This is a very good reference book which has absolutely hundreds of colour photos of both the interior and the outside of the 'old gal'.
As I say, I'm no expert at this and other shipmates might be able to enlarge on this subject. But anyway, I hope this helps you a little.
Happy building
David
