Joined: 04/06/2010 Posts: 332 Points: 1,000 Location: Bannockburn
Juat a thought for those buying the binders. Each binder holds 20 magazines so 6 binders are required for the main build. The cross section build is issues 121 to 150 so is there going to be two smaller binders holding 15 issues or one larger binder holding all 30 issues?
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Is the cross section a continuation of the full ship or a separate subscription? I have looked at the main web site but can't see the cross section for sale. Thanks Riff-Raff You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
I don't beleive the binder format will change.
The cross-section is a continuation of the Victory series rather than being a new series as such, though you can opt out if you choose.
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
I though the choice was to opt in thrather than to opt out AND HOW DO YOU OPT OUT is it another phone call it's this or the sovereign of the seas not doing the two
Tomick wrote:I don't beleive the binder format will change.
The cross-section is a continuation of the Victory series rather than being a new series as such, though you can opt out if you choose. Hang on, are you saying I will receive issues past 120 without formally agreeing to? John
I would have thought subscribers will end at 120 unless you opt in. Some newsgents have continued to roll it out into the cross-section, where you can choose to opt out if you wish.
Thanks Tom.
I am a subscriber so could Admin confirm please, that I need do nothing for the issue to stop at 120.
John
Thanks Tomick - Just wanted to check. I like the idea of the cross-section but I am torn between the Cross Section and the Sovereign. Gets quite expensive as I am building the Suprise as well. Riff-Raff You do not need a parachute to skydive. You only need a parachute to skydive twice.
There's also a huge difference in the space to display the Cross-section compared to the space needed for the SotS, which might sway your choice.
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
I rang CS to enquire about opting out of the cross section.....they didn't have a clue what I was talking about...as far as they are concerned there is no cross section Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Admin clarification would be good at this point.
John
Tomick wrote:There's also a huge difference in the space to display the Cross-section compared to the space needed for the SotS, which might sway your choice. cant stand bits or parts of ships or with sides missing like the bounty which i filled in to make a complete ship
z8000783 wrote:Admin clarification would be good at this point.
John From Admin..
Subscribers will have to ‘Opt in’ to the Cross-section. All will finish at issue 120, so you have to positively 'Opt in' if you want the Cross-section.
A Cross-section offer insert is being enclosed within Subscribers next dispatches. Which will offer Subscribers issue 121 FOC, and then if you wish to continue, you will in effect start from 122, but you must 'Opt in' to be receive it.
The customer service contact number for the Victory and Cross-section is: 0845 01489 213
For Retail/Newsagent customers, if you have a 'shop save' running, this should continue into the Cross-section series as long as the retailer continues to order. Therefore if you are a newsagent customer and don't want the Cross-section, you will need to tell your newsagent to end your Victory shop save at 120, or if you want the Cross-section, check that your newsagent has continued to order, and 121 onwards should follow.
