56 Pages «<3940414243>»
#801 Posted : 23 August 2012 16:27:39
ISSUE 48
The tools I will be using are here:-
#802 Posted : 23 August 2012 16:32:35
ISSUE 48
Here are the parts firstly on the sprue and the fret, and secondly when I had removed all the parts from same:-
#803 Posted : 23 August 2012 16:37:30
ISSUE 48
I began to prepare the parts and fit them as per the instructions, first inserting the muzzlesinto the barrels, then I fitted parts 223, 224 and 225 to the turret:-
#804 Posted : 23 August 2012 16:40:45
ISSUE 48
I then concentrated on the range finder and fitted that:-
#805 Posted : 23 August 2012 16:46:18
ISSUE 48
Finaly I dry fitted the barrel into the blast bag and dry fitted this assembly into the turret, I will fit them permanently further in the build, you will see I have fitted the range finder on top of the turret:-
#806 Posted : 23 August 2012 16:50:39
ISSUE 48
Well team thats it for this Issue, do not forget to note the addendum of parts ref numbers 9-10-11-14-15 and 18. I have more to follow soon, please feel free to ask questions or make commentsBigGrin Kind regards Mike
S2ksean
#807 Posted : 23 August 2012 17:52:45
Looks brilliant mate. Glad ya enjoyed ya holiday. Can I ask why u have decided not to secure the blast bag and Barron to the turret? Is this because they will be easier to paint?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#808 Posted : 23 August 2012 19:58:38
Hi Sean, yes once the turrets have been painted, I will then assemble the barrels and blast bags. I believe the blast bags will be a different colour, so it is easier to leave them off at this stageBigGrin Kind regards Mike
mark 2
#809 Posted : 23 August 2012 20:18:33
Hi Mike.
Thanks for the heads up on the blast bags.
Glad you are back in the fray of things.
Best regards.
#810 Posted : 23 August 2012 20:23:02
mark 2 wrote:
Hi Mike.
Best regards.
Hi Mark thank you for the kind wordsBigGrin Regards Mike
#811 Posted : 23 August 2012 21:11:30
ISSUE 49
Hi Team in this issue we receive a sprue with parts to make gun barrels, blast bags and the ends of a range finder;-
harty
#812 Posted : 23 August 2012 21:16:22
Turrets look good Mike but I am kinda surprised you did,nt fit turned ally barrels but you must have a good reason for thatBigGrin
#813 Posted : 23 August 2012 21:18:05
ISSUE 49
We only need to take the parts I mentioned off the sprue leaving the other parts for later in the build:-
#814 Posted : 23 August 2012 21:20:56
ISSUE 49
As we did in issue 48 glue the parts together;-
#815 Posted : 23 August 2012 21:29:17
ISSUE 49
Please file the joins so that they are all smooth.
Thats all for issue 49, and I will see you at issue 50.
Comments and questions welcomeBigGrin Regards Mike
willie
#816 Posted : 24 August 2012 10:43:04
the blast bags are satin or matt white to look like white wash
Ger C
#817 Posted : 25 August 2012 02:20:40
You're build looks great(as usual)Drool ,
but I am surprised with the amount of plastic parts on this model, not sure if it makes a difference to the finished model but I see a lot of people searching for after market product items
#818 Posted : 25 August 2012 13:41:13
Hi Ger, I do not think it matters to much, about after market products on this model they are so small when they are painted you will not be able to tell, plastic or metal?BigGrin Regards Mike
#819 Posted : 25 August 2012 13:42:40
Hi Harty, once they are painted you will not noticeBigGrin Regards Mike
mark 2
#820 Posted : 25 August 2012 20:35:06
Hi Mike.
I just wanted to say how much i am enjoying this build and hope you are too BigGrin .
I would like to have done the Bismark Mad .
Maybe they would release it again.
Anyway i wont Flapper anymore.
Best regards my friend.
Guest (5)
This page was generated in 1.266 seconds.
