Advice sought. Options
Mo
#1 Posted : 20 August 2012 22:55:55
Timber Required.
I am trying to form my edging plank round the bow of the ship. See the pictures below of how I am trying to achieve that, I have used a piece of plywood, but when cut to 5mm wide, It is just breaking at the short grain end, Any ideas of what material I could use to stop this breaking, or any other tips.
First picture is the bow with one bulwark plank in place.
The next step is to make a paper template of the curve.
I then put the paper template on the deck and trapped the bulwark plank on top of the template and drew around the bulwark plank to get the radius curve.
I then marked the curve on the plywood and cut to the curve.
I worked out pretty well, apart from the fact it keeps breaking at the short grain point.
Any advice on material I should be using and a supplier would be very helpfull to apprentice builder.
Mo
Mo
harty
#2 Posted : 20 August 2012 23:22:33
I done mine in 2mm sheet ply the same way as you are doing it. Try cutting it a little oversize and then sand it back with progressive grain of sand paper also I didnt have the bulkheads in the way. I cut to them and not around them. This let me remove the complete deck for easier working. Hope this helps a bitBigGrin
#3 Posted : 20 August 2012 23:43:54
Just an idea, make template of the full curve, like the half template you already did but a full round of the curve your after. Then soak your wood for a good couple of hours fit around the template with elastic bands/clamps leave to set overnight this should leave you with the desired full curve your after
Dontshootme
#4 Posted : 21 August 2012 08:38:33
Cornwall Model Boats used to stock some flexible 5x2 planks that allow sideways curves like your trying to achieve,I have used it & provided you soak it then it takes & holds quite tight curves...wether they still stock it is another matter...just taken a look...heres the link http://www.cornwallmodel...log/beech-flexible.html
Hope this helps
iain1/96
#5 Posted : 21 August 2012 10:41:32
Mo wrote:
Timber Required.
Mo
hi Mo,
I am not sure if my last message got to you so, I will reiterate.
Isuggested that you made the margin plank the same way as the shipwrights did and suggested the you look at Chris's build or, krt2's log on medelshipworld.com Click logs for kits, the wooden kits and fially, Surprise in the index.
Regards & Good luck,
Iain
This page was generated in 0.697 seconds.
