Removing Adhesives Options
Glen
#1 Posted : 20 August 2012 19:45:35
Hi All,
I have just started to copper the hull,but iam having trouble with the glue (trying super glue, three types of contact glue and now trying adhesive spray glue).
Super Glue works but the corners keep sticking up, contact glue works until you try to clean the excess off, then the tile comes off with it and that's waiting at least 48 hrs.
I have tried cleaning the tiles with a dremel but all that happens is the tiles shoot off all over the place.
Next step 6" nails.
Anyone out there know how to get the glue's off the copper tiles?
Iam ruining moretiles than iam using at the moment, it looks a right mess.
Someone please help.
GlenCursing
Roger the Cabin Boy
#2 Posted : 20 August 2012 21:28:43
hi glen,sorry 'bout your probs,this has happened to all of us at sometime or another,the only way is to test first a few tiles on a spare plank,decide your adhesive,and very sparingly do one tile at a time,and clean up as you go.if you've got superglue bits on the hull you'll have to sand these off,any paint wash off you not gonna like this but,you've got to start again,and read up on some of the build diaries,and stick (forgive the pun)to it,using only one adhesive,I think your safest bet would be aliphatic clue,and wipe with a damp cloth as you go.it will start to set in 10 min.so you have time to move things about.good luck and don't give upBigGrin
z8000783
#3 Posted : 21 August 2012 10:36:49
Groups: Unapproved
Hi Glen, have a look here.
John
Glen
#4 Posted : 21 August 2012 13:59:46
Hi Karl,
Thank's for the reply.
Could you tell me what Aliphatic Glue is?
And what sort of name to look out for.
Thank's again,
GlenConfused
Roger the Cabin Boy
#5 Posted : 21 August 2012 15:00:02
hi glen try this web site.http://www.cornwallmodelboats.co.uk/acatalog/wood_glues.html
willie
#6 Posted : 21 August 2012 15:02:37
how about trying put vaseline on the outer face of the tile and then glueing the glue willnot stick to the treated face and a little wipe at the end to remove the vaseline with white spirit,and this goes for anny type of glue used
#7 Posted : 22 August 2012 08:26:36
I have used neat PVA. It holds very well but easy to remove tiles if you have to and easy to get of top surface of set tiles also.
its also the cheapest glue BigGrin
This page was generated in 0.104 seconds.
