hi Steffan Looking good, keep up the good work. Thanks for the info on the glue. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Looking good there Stefan, keep it up. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Thanks lads! All the tiles on the Port side of the keel have now been fitted and both sides filed level with the keel  Starting to tile the bottom of the keel  Progress as at close of play last night
Your doing great Stefan, can't wait to see the finished work... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
 Thanks Jonny. How's you build coming?
Tiles are looking good Steffan. keep up the good work Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
StefanDV wrote: Thanks Jonny. How's you build coming? Slow but sure mate..Just started issue 78...Will post some progress pics shortly...Keep up the brill work Stefan.
This is what my build dairy has descended into: a never-ending array of pictures of little copper bits! 10 rows of tiles laid down on the starboard side:  After the 4th row of tiles on the stern, I'm going to be needing some stealers  The 10th row at the bow. Not too long before they'll be meeting the waterline
Hi steffan. Looking realy good.I have got the pleasesure of tiling to come when i get to that stage. it is worth all the effort and time it takes, the end result looks fantastic. ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Nice job with the tiles. don't forget to put some stealers in at around the 8/9th row. You will know when to do them as the line of tiles wants to run away from the preceeding one. Steve..
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
just as an added help but i would try to even up the layers for both sides, just that the shrinking of the glue as it dries when fixing the tiles might slightly warp the hull, and as your putting such good work into her i would not want this happen so far down the line. Hope i have not offended you with this surgestion its just an observation. keep up the great work your doing. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Thanks lads! All your comments are greatly appreciated. (Petpole: With the tiles being discrete elements, I don't think that any warping will take place, but thanks for raising the point to ponder  ) I've continued the tiling on the starboard bow until it met the waterline:  Marking the size of one of the filler pieces that is required.  All the gaps against the keel and some against the waterline filled  Continuing to tile the Starboard bow
Very nice Stefan, I shall follow your lead.
John
Looking great there wished i had for that now but i think im to far gone now but looking fantastic keep up the good work. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Great job sofar Stefan Bit it looks like I have to plan in several Weeks to komplete this job
 Rank: Amateur Level 1  Groups: Registered
Joined: 19/03/2012 Posts: 34 Points: 95 Location: Manchester
Hi stefan great job.I have seen a lot of people gluing a row of tiles running along the waterline?i know this is how deagostini told people how to tile but is it right?Unless I've done it wrong! I found it Easyier to continue tiling to the waterline especially around the stern end.I know there was a lot of cutting the tiles a different angles but you have to do that anyway.have a peep at my build,I think it make's it look a bit neater. I might have done it completly wrong anyway. Superb job you are doing though.
Nice job with the tiles! I too followed the Deagostini recommendation for fixing the tiles, as our shipmate Benten mentions tiles without a border look neater. However I have seen both methods used by lots of builders and as long as the tiles go on in straight lines my personal opinion is do which ever makes you feel most comfortable with. It's a long slow haul but the final appearance makes it worthwhile. All the best, Steve..
Thanks gents! @Ben Ten - I've admired your fantastic build dairy numerous times. I didn't think I could pull it off, so I followed the DeAg instructions. PS. my boy really enjoy your show!
Hi Stefan your build looks great  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Steffan. Looking great, keep up the good work Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Guest (11)
