22 Pages «<1718192021>»
Stefan's build Options
#361 Posted : 06 August 2012 18:14:26
hi Steffan
Looking good, keep up the good work. Thanks for the info on the glue. IanCool
Hans
#362 Posted : 07 August 2012 10:01:48
Looking good there Stefan, keep it up.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
StefanDV
#363 Posted : 16 August 2012 14:00:07
Thanks lads!
All the tiles on the Port side of the keel have now been fitted and both sides filed level with the keel
Starting to tile the bottom of the keel
Progress as at close of play last night
jonny7england
#364 Posted : 16 August 2012 15:44:42
Your doing great Stefan, can't wait to see the finished work...ThumpUp
StefanDV
#365 Posted : 16 August 2012 16:12:10
Blushing Thanks Jonny. How's you build coming?
#366 Posted : 17 August 2012 14:51:23
Tiles are looking good Steffan. keep up the good work Ian Cool
jonny7england
#367 Posted : 17 August 2012 20:11:56
Slow but sure mate..Just started issue 78...Will post some progress pics shortly...Keep up the brill work Stefan.
ThumpUp
StefanDV
#368 Posted : 22 August 2012 09:56:31
This is what my build dairy has descended into: a never-ending array of pictures of little copper bits!
10 rows of tiles laid down on the starboard side:
After the 4th row of tiles on the stern, I'm going to be needing some stealers
The 10th row at the bow. Not too long before they'll be meeting the waterline
#369 Posted : 22 August 2012 13:13:40
Hi steffan.
Looking realy good.I have got the pleasesure of tiling to come when i get to that stage.
it is worth all the effort and time it takes, the end result looks fantastic. ian Cool
farrabass
#370 Posted : 22 August 2012 15:07:09
Nice job with the tiles. don't forget to put some stealers in at around the 8/9th row.
You will know when to do them as the line of tiles wants to run away from the preceeding one.
Steve..
petpole
#371 Posted : 23 August 2012 00:24:09
just as an added help but i would try to even up the layers for both sides, just that the shrinking of the glue as it dries when fixing the tiles might slightly warp the hull, and as your putting such good work into her i would not want this happen so far down the line.
Hope i have not offended you with this surgestion its just an observation.
keep up the great work your doing.
StefanDV
#372 Posted : 28 August 2012 22:36:22
Thanks lads! All your comments are greatly appreciated.
(Petpole: With the tiles being discrete elements, I don't think that any warping will take place, but thanks for raising the point to ponder BigGrin )
I've continued the tiling on the starboard bow until it met the waterline:
Marking the size of one of the filler pieces that is required.
All the gaps against the keel and some against the waterline filled
Continuing to tile the Starboard bow
z8000783
#373 Posted : 29 August 2012 07:51:06
Groups: Unapproved
Very nice Stefan, I shall follow your lead.
John
petpole
#374 Posted : 29 August 2012 21:38:45
Looking great there wished i had for that now but i think im to far gone now but looking fantastic keep up the good work.
Jesus-Belzheim
#375 Posted : 30 August 2012 12:46:51
Great job sofar Stefan ThumpUp
Bit it looks like I have to plan in several Weeks to komplete this jobBigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
Ben ten
#376 Posted : 30 August 2012 16:11:53
Rank: Amateur Level 1
Hi stefan great job.I have seen a lot of people gluing a row of tiles running along the waterline?i know this is how deagostini told people how to tile but is it right?Unless I've done it wrong! I found it Easyier to continue tiling to the waterline especially around the stern end.I know there was a lot of cutting the tiles a different angles but you have to do that anyway.have a peep at my build,I think it make's it look a bit neater. I might have done it completly wrong anyway. Superb job you are doing though.
farrabass
#377 Posted : 31 August 2012 00:09:45
Nice job with the tiles! I too followed the Deagostini recommendation for fixing the tiles, as our shipmate Benten mentions tiles without a border look neater. However I have seen both methods used by lots of builders and as long as the tiles go on in straight lines my personal opinion is do which ever makes you feel most comfortable with.
It's a long slow haul but the final appearance makes it worthwhile.
All the best, Steve..
StefanDV
#378 Posted : 04 September 2012 12:18:09
Thanks gents!
@Ben Ten - I've admired your fantastic build dairy numerous times. I didn't think I could pull it off, so I followed the DeAg instructions.
PS. my boy really enjoy your show! BigGrin
#379 Posted : 04 September 2012 16:20:04
Hi Stefan your build looks greatBigGrin Regards Mike
#380 Posted : 04 September 2012 16:55:24
Hi Steffan.
Looking great, keep up the good work IanBigGrin
Guest (9)
This page was generated in 0.159 seconds.
