Hi..You should have got nails with issue 17 and a cannon with issue 18 mate..but more pins with issue 20.. Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 11/03/2012 Posts: 19 Points: 57 Location: Lincoln
All i have so far are the decks and stuff. No cannon or nails for the deck !
Joined: 08/02/2012 Posts: 61 Points: 186 Location: N. Wales
I'm the same .Did not receive a cannon in 14. It shows you building a cannon in 14, but the " Assembly Guide - your latest parts" doesn't show a cannon supplied. Had some pins in one of the issues i had between 15 - 18, although the parts count didn't say you were getting any. Must have been lucky. Have now received 19 - 22 and had pins in 20,21 and 22 as per magazine. Mal. Mal.
Built:
Caldercraft - HM Cutter Sherbourne.
Thanks Mal. Ill wait until next month and see if i get them then.
