 Rank: Pro Groups: Registered
Joined: 30/06/2012 Posts: 207 Points: 583 Location: Dunfermline, Scotland
Hi guys, sorry to go on about glue again but i'm still having problems with it.Took Tomick's advice & bought some 4 min Speed Epoxy from Deluxe Materials.I read the instructions & mixed it half & half.I held the parts together for 5 mins but it didn't bond.Am i doing something wrong? Should i add more hardener to the glue mix or more adhesive? The model is getting to the stage now where any mistakes will be visible.Thanks for your patience.
Joined: 27/03/2011 Posts: 72 Points: 186 Location: United Kingdon
I dont see why people are going for the complex stuff. Go to your local Wilkinsons and get the green tube "hard plastic glue", bonds in seconds, no trouble.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,188 Points: 15,713 Location: ipswich
dave1978 wrote:I dont see why people are going for the complex stuff. Go to your local Wilkinsons and get the green tube "hard plastic glue", bonds in seconds, no trouble. Ditto.... I've used this stuff on plastics ranging from airfix-type kits right through to rigid stuff almost as hard as Perspex. No probs. "Sticks like sh-t to a blanket" as they say. Roy.
Thanks for the advice.Will buy some & give it a go.
Joined: 20/12/2011 Posts: 134 Points: 384 Location: barnoldswick
loctite super glue tube and brush simples.com it works a treat as this is my first build im a happy man with it as you only need a tiny little bit done and dusted
Joined: 31/08/2011 Posts: 629 Points: 1,963 Location: Plymouth
roymattblack wrote:dave1978 wrote:I dont see why people are going for the complex stuff. Go to your local Wilkinsons and get the green tube "hard plastic glue", bonds in seconds, no trouble. Ditto.... I've used this stuff on plastics ranging from airfix-type kits right through to rigid stuff almost as hard as Perspex. No probs. "Sticks like sh-t to a blanket" as they say. Roy. Does this glue have the 'bloom effect' though?? Chris
