Joined: 10/10/2010 Posts: 690 Points: 2,133 Location: Dorset
I was going to try the suggested method of using 1mm wide masking tape but as I have had some problems in getting hold of the stuff without buying a load of additional tape I did not want. I first tried using cut down masking tape that I had but the results where not good.Painting the vertical strips was not an option for me. After some pondering I remembered that some of the 5 X 1 X 30 mm strips supplied in a previous issue where in fact two .5mm pieces glued together.(Some separated when I was soaking to bend them) So I tried this Cut 1mm strips from the lengths and soak them for a while, it will then be easy to separate then and you end up with lengths of 1 X .5 mm strips Paint these yellow ochre and attatch to the windows to create the vertical window frames. Easier to handle then tape and gives some depth to the vertical window frames Will add pictures when I have completed this step Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
sounds a great idea “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
hi gil,if you check my build you will see a similar method to what you just described,only what i did was paint a 3mm x1mm strip french blue,and then paint 1mm x1mm strip yellow ochre,then stick the 1x1mm to each side of the3x1mm.then when all dry cut what lengths you need for the window frames.also used this method for the bow decoration. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Well some 104 pieces of wood later the gallery is finished. Will let the paint dry for a couple of days and then see if any minor touching up is required. Picture attached GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Looks great matey!! “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
stunning Come on you Jimmies
Hi Gil, What a great job you have done Gil,I mean Deagostini look's a hard build to do. Well done mate. Regards tf64. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Hi Gil You did a great job on your Galery, It`s looking great
Beautiful job there Gil absolutely beautiful Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
