Issue with issue 64 Options
Skiddy
#1 Posted : 31 July 2012 14:11:00
The two parts are not same size ! Have filed the end of the smaller part (red end) but it's still too long. Have tried to glue together but the the veins in my hands are bursting trying to keep glued
The other side was fine.....what's going on ?
Now have a throw away issue 64.
Tomick, advise please
lholland
#2 Posted : 31 July 2012 14:22:13
I found both sides very tough when I first did the trial placement and was going to ask the same question. I must admit after that I decided to use my super glue gel on this one which seems to have worked fine. I shall use this glue on other parts such as the side pods too to ensure a strong hold.
Smeg and the Heads
#3 Posted : 31 July 2012 14:35:59
Hi Skiddy
I too had a problem with issue 64, my problem was the bent peice must have been squashed a little in the post but I only noticed when I tried to assemble the parts, luckily with a bit of care I managed to bend it back into the correct angle then it fitted perfectly, I was a little nervous as I expected the silver paint to crack but it didn't.
only1ianuk
#4 Posted : 31 July 2012 15:59:40
Mine seemed fine but wait until you try piecing the lower engine cowl round the exhausts! Its extremely tight and i had to slowly "bend" the exhausts in towards the engine to light it up! Still not sure its gonna fit!
#5 Posted : 31 July 2012 17:08:17
Other than needing great care to fit togther, I didn't exerience any difficulty in fitting them togther.
Have you checked that the smaller part has the right shape compared to the opposite side. It could be that you have a rogue part?
Skiddy
#6 Posted : 31 July 2012 18:02:55
I have used masking tape to temporarily fix at the top to show that it is tooo long to fit in....even with the bottom filed to shorten it. The other side is fine. It's difficult to compare shape but it doesn't look wrong to the other side.
only1ianuk
#7 Posted : 31 July 2012 19:02:57
Hi Skiddy,
Don't take it the wrong way but it looks like you've tried to get the edges flush which there needs to be a gap and over lap of a couple of mil. Might just be the camera angle though!
#8 Posted : 31 July 2012 19:57:05
Skid,
To me that looks like a crease at the corner of the curve going by your picture.. I would get a replacement sent as looks damaged in transit...
S2ksean
#9 Posted : 31 July 2012 21:23:13
Have to agree with warty on this one the part doesn't look right
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#10 Posted : 31 July 2012 21:29:18
It does indeed look like you have a rogue part...
Skiddy
#11 Posted : 31 July 2012 22:00:59
Thanks for the sharp eyes guys....have a look at this one and it will confirm...sorry about the chubby thumb.
Now I see that as the curve is less than it should be it's making for a longer part. Top man Warty !....now how do I get that issue replaced. Would I think Deag would be interested ?Blink
WRONG 002.JPG (1,125kb) downloaded 159 time(s).
#12 Posted : 31 July 2012 22:19:24
I'm sure Admin would be more than happy to help SkidBigGrin Luckily its not a part that will stop your build so you have 13 weeks to get it sorted or take the plunge and get a copy from ebay
Yeti-Man
#13 Posted : 01 August 2012 08:57:48
You really think they will be interested .... Have we not forgotten the paint issue's .... Huh
Skiddy
#14 Posted : 01 August 2012 20:38:38
Yes.....realise that, and that is a seperate issue to this.
I have to get to the end of the build with what we have at the moment but this is definately as Tomick says 'a rogue part'
Deag did replace a damaged binder for me without hassle and if they are looking at this they might step up and offer a replacement issue....I will wait and see.
only1ianuk
#15 Posted : 01 August 2012 21:29:26
I had no problems when i needed replacement issues. Just take about 2 weeks to arrive!
#16 Posted : 01 August 2012 21:40:10
Fire an email too Admin Skid, Don't wait for them to read this thread... not saying that they have'nt all ready but use the power of the force and the wonders of the world wide web and PM them with your details etc to speed things up
#17 Posted : 02 August 2012 09:49:37
Customer services will indeed replace the parts set
Skiddy
#18 Posted : 02 August 2012 21:08:02
Just sent email to customer services.....I await in anticipation.
Skiddy
#19 Posted : 03 August 2012 15:45:44
Still no reply ( next day )
Aha! Had a reply from Jackson Enterprises at 16.19 saying I should recieve within 7 days.....thankyou Louise, miracles can happen after all.
Skiddy
#20 Posted : 09 August 2012 18:19:21
Just thought I would update and give credit when it's due !
Arrived within the 7 days quoted and the parts fit perfectly this time.
This page was generated in 0.179 seconds.
