Trying to help my neighbour (Part 70) Options
Warren4Peter
#1 Posted : 30 July 2012 20:01:12
Rank: Newbie
Hi,
I live in the Netherlands, and I have not come across a Dutch support forum for the HMS victory (if anyone is aware of such a forum, please let me know).
I am not building the model, my neighbour is building it and there is no customer support in the Netherlands, nor does he use computers, hence I am posting on his behalf.
He is trying to figure out what to do with parts 70, as he has not seen instructions on how to use these pieces.
1.Is this the correct forum to post this question?
2.can anyone provide any feedback to this request (I have searched for (70) but have found nothing in these forums.
Thanks and Regards
Warren (for neighbour Peter)
#2 Posted : 30 July 2012 20:23:01
Hi Warren,Welcome to the Model Space Forum. what a good friend you areBigGrin If you go onto the Official Victory Build, built by our official builder Tomick, you will see the post you want by looking through this great archive.
I hope that helps you and Peter, Best wishes MikeCool
#3 Posted : 30 July 2012 20:23:38
BigGrin Hi Warren
do you mean magazine issue no 70 or part no 70,if its the magazine issue then look in the 'Official HMS Vic Build diary' for the issue's covering no's 66 to 70 posted by Mr T on the 28/07/11. Hope this is some help to your neighbour
janzwart
#4 Posted : 30 July 2012 21:30:14
Rank: Beginner Level 3
Hi Warren
May be you can look to the next site.
There a group of Dutch Victory builders, I am one of them, are discussing there problems with building the Victory.
Kijk maar eens op de volgende site:
http://www.modelbouwforu...tory-deagostini-70.html
Good luck and see you there
Jan Zwart
Current build: HMS Victory
Already built: Half moon, Stadt Bremen.
janzwart
#5 Posted : 30 July 2012 21:38:55
Warren,
Do you mean with the pieces in issue 70 the metal things like an "accolade"?
That are the "regenafleiders". Mounting these is described a future issue.
You have to keep these parts till you have to use them.
Jan Zwart
Son of Bulwark
#6 Posted : 30 July 2012 23:04:42
Hi Warren! Cool
You can tell your neighbour Peter that the parts 70 are supplied in issue 41 and they are the large triangular shaped parts there are 6 of them, these go under the gallery sides 3 on each side to build the curved part of the gallery support and need to be shaped to fit close to the hull sections and are fitted in issue 76.
The link to the Official HMS Victory Build Diary by Tomick is below and shows these parts:-
http://forum.model-space...s&m=32966#post32966
I hope this helps!
Darron
Warren4Peter
#7 Posted : 05 August 2012 15:52:24
Rank: Newbie
Wow, thanks for all the reactions, this is a great friendly forum :-).
@ Son of Bulwark, you have the answer spot on, thanks a lot.
@Jan Zwart. Ook U bedankt voor de toelichting , dit heeft my in ieder geval goed geholpen. Mocht ik jullie nogmaals nodig hebben zal ik niet twijfelen jullie te raadplegen op modelbouwforum.nl (Peter)
Warren
Lucien
#8 Posted : 07 August 2012 17:47:34
Hello Warren
For these sort of problems i use the translated guide wich you can find on the dutch Deagostini site.
https://www.deagostini-b.../gtb_montagelogboek.php
It is basicly the same as Tomicks guide but translated to dutch.
If you look at issue 41 you can see the parts 70 are supplied but are not needed yet.
Greetings from Belgium.
Lucien
This page was generated in 0.302 seconds.
