4 Pages <1234>
Bameraam's build Options
Bameraam
#21 Posted : 24 July 2012 14:09:50
Mid deck planking finished:
And finally completed the design on the interior.. this is rev3 :p
What i don't seem to find pictures from though, is from this deck & more especially what stuff i should place there (or not), like barrels, ... ?
Some links to good pictures/plans would be v much appreciated!
Cheers
Bam
#22 Posted : 24 July 2012 19:43:18
hi Bameraam, lovely decking and working lights design,and the graphics are excellent,will be keeping my good eye on this build.
Bameraam
#23 Posted : 24 July 2012 21:21:36
Thanks Karl!
In the mean time finished the upper frame work:
Milled out some strips of nutwood (4.2 by 2.1mm) so they fit together
Dryfitted them here, (some small adjustments needed to keep a right angle though). Can't glue them together yet as i need to foresee the lighting spots first and mill out the gutters for the wires
Bameraam
#24 Posted : 25 July 2012 15:32:26
Holiday for me, so work advances quite a bit BigGrin
Milled out the LED spaces, the wire holes & the wire gutters:
Best regards!
#25 Posted : 25 July 2012 15:55:15
Very nice work Bameraam, can't wait to see the end result Cool
harty
#26 Posted : 25 July 2012 23:21:32
Excellant deck work and the frame ,top job,speechless about the restLove Love Cool BigGrin
Bameraam
#27 Posted : 26 July 2012 12:49:03
Frame assembled & sanded a bit.
Bought some pillars & extended them with a 3mm diameter wooden piece to get to the correct height to support the lighting/support frame.
Dryfitted:
..and the view later on through the door
A bit worried though with the angular lightcone, hopefully the height will be good & i don't get "spotlights" only illuminating circles on the deck. Ach well - we'll see later on i guess Cool
#28 Posted : 26 July 2012 15:32:53
Hi Bam very nice workBigGrin Agreat enhancement Kind regards Mike
Bameraam
#29 Posted : 27 July 2012 18:49:14
Finally finished with the frame, had a hard time on it:
solders breaking, resistors breaking when fixing the lightpoint.. anyways here is the result, and I'm happy with it BigGrin BigGrin BigGrin
The topside with the wiring
An LED
All lighting up, hope it stays this way
The wires are all coming out of the sides, as there's another deck to put on top of this one
From the entrance, pillars not fixed yet
At night :)
Best regards,
Bam
S2ksean
#30 Posted : 27 July 2012 19:33:14
Looks fantastic mate. Can I ask where u got all the lighting equipment from as I'm building HMS hood and would love to light it up
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Bameraam
#31 Posted : 27 July 2012 20:43:58
Sure, i bought the parts at a local electronics shop.. nothing too special. What you want is SMT components, as those are the smallest. So here i use yellow SMT LEDs and SMT resistors in series. The shape is "0805"
Have to know something from soldering as well, as it's not easy i find in these dimensions.. and i have about 12yrs experience in it..
You could go for bigger components, but then it will take more space in your model.
Have to know a bit electronics as well if you intend to use µcontrollers like i did. Otherwise you could directly connect the LED/resistor sets to the +5VDC power & then everything will shine at 100%. A bit more straight forward that.
Can highly recommend it, and with a bit of patience anyone can do it! Id say go for it :)
Best regards
#32 Posted : 27 July 2012 21:10:23
brilliant mate,can I make a comment 'bout your wood pillars.instead of using dowel(round)why not us square section top and bottom as spacers,it gives the pillars a more authentic look.you can still get the same dimensions as you've already got.but what a great looking ship,well done mate.
Bameraam
#33 Posted : 27 July 2012 22:03:58
Thanks for the nice words & tip Karl.
Didn't know that was more authentic..
Can give it a try & see the difference.
So from bottom to top: square piece, pillar, square piece?
The problem i noticed with the dowels (learned a new word, thnx :p) is that their height is very small, tending to not being able to fix it during milling..
Best regards
#34 Posted : 27 July 2012 23:26:40
I should have been clearer mate,square base piece and square top piece,and you adjust the thickness to suit the height of the pillar.
the dowel(our word for round wood lengths)if the dowel is 6mm,then use 6mm square wood lengths,if the space from deck to ceiling is 30mm. pillars cut at 25mm.and square spacer of 3mm.and 2mm. 3mm. base and 2 mm.for the top of the pillar.hope that is clearer.and keep up the good work. so lets recap one pillar= 6mmx3mm sq,base, 25mm x 6mm pillar and 6mm x2mm sq.top piece.I wish I had a pic to show so much easier. or keep me mouth shut,and not get involved,LOL LOL
Bameraam
#35 Posted : 28 July 2012 00:23:28
Yea that's what i meant too LOL LOL
#36 Posted : 28 July 2012 09:10:31
it's an unfair worldCrying why have some people got soooooo much skill and others have not much????????---------------------->gonna go and hide in a corner and cry.Drool Drool Drool Love Love Love those graphicsDrool
Bameraam
#37 Posted : 28 July 2012 09:50:39
Oh my - let me tell you it's a freeware software from Google: "Sketchup". Once you get the hang of it (and the "hang" comes fast), you can do almost anything with it.
Try it out.
It even contains a online library with 3D models you can import. And - surprize - I found a pillar there BigGrin BigGrin BigGrin
#38 Posted : 28 July 2012 09:59:29
BigGrin Hi Bam
Thanks for the info on the free software downloaded it straight away iv been looking for something like this for a while and nice enhancments with the lights
S2ksean
#39 Posted : 28 July 2012 15:25:54
Are these any good and if so what else will I need and where would I get them from
http://www.cornwallmodel.../acatalog/gow-bulbs.html
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Bameraam
#40 Posted : 28 July 2012 16:11:11
[quote=S2ksean]Are these any good and if so what else will I need and where would I get them from
http://www.cornwallmodel...acatalog/gow-bulbs.html[/quote]
Well i think they might do well. A non-LED won't last as long
In any case, its better to order like 5pcs for example & see what effect you get before you purchase a lot of them.
As these are not LEDs, you won't need a serial resistor to limit the current, so you can ommit that
So far as i understand what you'll do, this is what you need:
Power supply providing the voltage + current mentioned (of ALL lights that you'll fit, need to sum up the current & the PS should be able to deliver that current)
wire to connect all light bulbs together in parallel
wire stripper to remove the insulation
soldering iron
solder 1mm diameter (take the one with lead, solders better)
shrink sleeve (optional)
some tantal capacitors rated for the voltage & with adequate capacity (will improve stability of the light)
Some means of connection once the boat is finished, perhaps a mono audio jack set? (Edit: make sure the Powersupply is set off when making connection with this, there's a risk of shorting the ground & power when making the connection)
I also recommend going by a local electronics shop, they'll provide explanation too (& solution based on your description what you want to achieve). Everything listed above should be purchaseable in that same shop
Guest (5)
4 Pages <1234>
This page was generated in 0.222 seconds.
