9 Pages 123>»
MWG build diary of the HMS Victory X - Section Options
#1 Posted : 23 July 2012 12:06:26
Hi Team,
Well here we go again, I am really looking forward to building the X - section the opportunity to add accurate detail to and in this 1/72 scale Hull of Englands finest ship could not pass me by I am very excited at the prospect.
I hope to have the opportunity to add some enhancements, when we see what is being included in the build.
I will certainly add a full mast with standard rigging, as I see from graphic that Admin posted, that a stubb mast is planned for the build.
I shall be off to the newsagent this week to see if ISSUE 1 is out.
WATCH THIS SPACE!BigGrin Kind Regards Mike
harty
#2 Posted : 23 July 2012 12:15:23
I will be watching with great interest this space to see what exellance in enhancements you come up with MikeBigGrin
#3 Posted : 24 July 2012 10:16:10
Hi Harty thank you for your nice commentsBigGrin Regards Mike
#4 Posted : 27 July 2012 14:59:25
Hi Mike.
look forward to seeing your new build. Ian
#5 Posted : 30 July 2012 19:06:04
ian smith wrote:
Hi Mike.
Thank you IanBigGrin Regards Mike
#6 Posted : 16 August 2012 17:53:06
Hi Team
So far I have just received today issue 124, I am waiting for 121 - 122 - and 123 from my newsagent, in issue 124 we have planking which is really good qualityBigGrin Regards Mike
Trotsky
#7 Posted : 16 August 2012 18:09:03
I have 121 123 124 ...and I agree it looks good quality but without 122 nothing gets done ...
H.M.S Victory
H.M.S Victory X Section
H.M.S Surprise under the bench
D-51
Trotsky
#8 Posted : 16 August 2012 18:10:11
H.M.S Victory
D-51
#9 Posted : 22 August 2012 20:05:59
Hi Team well so far I have received issues 124 and 125
#10 Posted : 22 August 2012 20:14:03
ISSUES 124 - 125
The wood we have received for planking outside and inside the hull is Lime wood, a good quality wood spoiled by the way it has been cut with a guillotine and really should have been sawn.
The planks I have received in both issues have round edges on them where the pressure of the guillotine has caused this. please have a look:-
#11 Posted : 22 August 2012 20:17:43
ISSUES 124 - 125
I am not asking for a replacement as it will take to long to replace, fortunately I have a stock of Lime wood 5x2mm and 5x1.5mm
#12 Posted : 22 August 2012 20:23:02
ISSUES 124 - 125
I still believe this will be a great partwork and I will be adding 1/72 scale copper tiles which I have sourced, and butted up to the tiles I will be double planking with 5x1mm walnut planking above the water line;-
#13 Posted : 22 August 2012 20:31:16
ISSUES 124 - 125
I will be adding a full size mast with standard rigging, and depending on what we receive other enhancements such as Boarding Pike (1/72 scale) and a mast head lamp which I have sourced, see photo.
as usual it will depend on other members wanting these enhancements, to get them at the right price -- hence my definition of TEAM--- Together Everyone Achieves More
Regards Mike
daffy09
#14 Posted : 28 August 2012 21:59:59
Hi Mike
Although I've only just received issues 110 - 114 of the main build, I have already decided that I'll be going on to the cross-section build.
I'd just like to show my interest in any enhancements you will be looking at for this build - I'd be interested in the full mast and the copper tiles just for starters.
P.S Haven't started on the gallery enhancement as yet because I'm waiting to see how others have coped with completely removing the old back board and side panels first. The two that I have looked have both added their enhancement kit over the back panel and although this looks amazing, I'd just like to see how a complete removal goes first.
Happy building
David
#15 Posted : 29 August 2012 11:33:53
daffy09 wrote:
Hi Mike
Happy building
David
Hi David I will send you some info when it is finalised on Xsection enhancementsBigGrin Best wishes Mike
#16 Posted : 29 August 2012 11:41:47
ISSUE 126
Hi Team just received the latest issue this morning this is what we received:-
1 1x14mm Dowel 300mm long (stubb mast)
2 4 wooden strips 1x3mm 300mm long
3 1 wooden strip 2x2mm 100mm long
4 Brown thread
5 Black thread
6 Laser cutmast step and platform frames
7 2x small barrels
8 2x small buckets
I am still waiting for Issues 121 122 and 123, from the newsagent.
Questions and comments welcomeBigGrin Regards Mike
#17 Posted : 31 August 2012 21:49:24
ISSUE 121
Hi Team I have just received issue 121, this is what I received:-
1 Laser cut rib frames
2 Large Barrels x 4
3 Small Barrels x 4
4 Rib assembly Plan
#18 Posted : 31 August 2012 21:56:26
ISSUE 121
I took the fret of parts and cut them all out and sanded and prepared them for putting them together:-
#19 Posted : 31 August 2012 22:00:45
ISSUE 121
I then took the Rib plan and fitted it to a flat surface with masking tape ( The flat surface I used was a 2ft square shelf left over from the fitted kitchen )
#20 Posted : 31 August 2012 22:03:46
ISSUE 121
The next job is to cover the Rib Plan with cling film, I did not like this idea so I used the plastic that the fret and parts came in:-
9 Pages 123>»
This page was generated in 0.345 seconds.
