Couldn't resist balancing it all together. RM1 attached the following image(s):
The latest delivery (including the first binder  ) . Looking forward to assembling the rear wing. RM1 attached the following image(s):
Joined: 31/08/2011 Posts: 629 Points: 1,963 Location: Plymouth
 Looking good mate....nice clean build! Chris
Thanks Chris. I really appreciate any comments and advice from fellow modellers.
The left side front nearly complete. I've taken a few ideas from Mr Warthog in the UK (the ultimate build). Still to decide if I'm going to put a Carbon finish on the brake ducts.I need to remove the ugly joint line in the duct. RM1 attached the following image(s):
The latest delivery PLUS the scale steering wheel RM1 attached the following image(s):
The story so far. Almost finished the front suspension, just removing the split lines on the front air ducts and respraying. Will do more on the rear wing this week. RM1 attached the following image(s):
Hi RM1 looking good  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 A really good build you have there....the carbonfibre detailing is excellent!!! Chris
Thanks Chris, The Carbon decals have been quite tricky but I'm getting the hang of it. Malc.
Wing complete. Quite a fragile construction. RM1 attached the following image(s):
Everything so far. RM1 attached the following image(s):
More parts  . The engine bits look really interesting. RM1 attached the following image(s):
Spending some time with carbon effect on rear hubs and spraying the attachment points on the suspension arms. RM1 attached the following image(s):
First part of the rear right corner nearly done. RM1 attached the following image(s):
Looking good Malc and comming along nicely
Joined: 10/05/2011 Posts: 204 Points: 631 Location: Morayshire
Nice looking build, at this rate you will be giving warty a run for his money Regards Bob Builds in progress
1/12 Spitfire (Deagostini) 1/8 McLaren (Deagostini) 1/16 Stuka (Hatchete) 1/16 Zero (Deagostini)
kwakermad wrote:Nice looking build, at this rate you will be giving warty a run for his money LOL malc's doing a good job at that already by the looks of it.. I'm surprised there are not more SA builds on here to be honest!!
Warthog wrote:kwakermad wrote:Nice looking build, at this rate you will be giving warty a run for his money LOL malc's doing a good job at that already by the looks of it.. I'm surprised there are not more SA builds on here to be honest!! LOL indeed !!  I've got a long way to go to get up to that standard. Thanks for the encouraging comments. I'm surprised as well about the lack of south african build diaries! Come on South Africa, where are you all.
New parts arrived  sadly 24 & 25 skipped but at least I can get on with the engine and parts of the gearbox. RM1 attached the following image(s):
