FORMING THE RUBBING STRAKES While the wood is still wet I bent them (using mini clamps) around the hull and left them to dry thouroghly ( at least 24 hours ):- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FORMING THE RUBBING STRAKES You can now see the shape firmly set in the wood, ready to fit. as you can see I take my time to achieve the build I want, it is not a race. Questions and comments welcome  thats all this time Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hello Mike,
I must say you are doing a great job with this Longboat, very neat and tidy and I love what you are doing with it! I have been watching your progress for a while now and I think your use of inks instead of paints is a winning method. It looks so much better and much more 'in scale'? Top build Mike, a craftsman at work, well done!
All the best,
Bernie.
Hi Mike, I agree with Monty there on this ink decor. It looks so much neater than paint and i think it would compliment something like danish oil or the like. Top job
Monty's Double wrote:Hello Mike,
All the best,
Bernie. Hi Bernie thank you for the compliment, the use of inks is not a new thing but it is for me, and as you say the covering is more to scale than paint, I will keep experimenting, the colour range is vast and you get more for your money plus more coverage per bottle  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
harty wrote:Hi Mike, I agree with Monty there on this ink decor. It looks so much neater than paint and i think it would compliment something like danish oil or the like. Top job Hi Harty, I agree with you on the danish oil, I am going to use that on the mahogany part of the build, testing an offcut first  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 04/06/2012 Posts: 19 Points: 57 Location: Pretoria (SA)
Hi Mike. She is looking stunning. One question, How do you keep up with all your build’s??? Built Albatross, build in 1982 from plans. Hms Bounty, build in 1987 from plans. Duyfken,build in 1991 from plans Oosterland, build in 1998 from plans
In the meantime. HMS Victory (Deagostini) 2011 Building MFV63 fishing trawler from plans. HMS Mayflower (Kit)
Wish list Still planning.
Sietsemk wrote:Hi Mike. She is looking stunning. One question, How do you keep up with all your build’s??? Thank you for the nice comment, I just do a little bit at a time, when the mood takes me  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
FORMING THE GUNWALES AND RUBBING STRAKES Hi Team as you know I have been experimenting with different colours of ink, which I am now using instead of paint, it gives a better scale coverage. In the photo you will see the ink as orange on the Longboat. I have also been experimenting with good quality felt tip markers and I am very impressed with the permanent twin tip PROMARKER by Letraset the colour I have used is umber. Please see the result on the Gunwales and I have added a bit on the end of the Rubbing strakes which are apple wood this product really brings out the grain, see what you think:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
This is how she looks the Gunwales are dry fitted. Thats all fo now questions and comments welcome  Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 06/08/2011 Posts: 480 Points: 1,421 Location: Galway
excellent work Mike
 Very nice work Mike, i too have used those inks in the past they give a very nice opaque finish as you say that shows the grain off well.My only concern with the pens your using is the fade over time if alowed to sit in bright light but i might be wrong there regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Very nice work Mike, i too have used those inks in the past they give a very nice opaque finish as you say that shows the grain off well.My only concern with the pens your using is the fade over time if alowed to sit in bright light but i might be wrong there regards Andy Hi Andy thank you for your comments, you are right about the fadeing, you must fix the surface after with a satin water based varnish. Your builds are looking great Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Really nice build Mike, interesting idea about using inks instead of paint, might have a play around with it my self Phil,
budgie wrote: Is there such a thing as being TOO GOOD In a word, absolutely NOT. John
Great build there Mike and some really good tips. Thank you. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Ger C wrote:excellent work Mike Hi Ger sorry I missed your post, Thank you for the nice comment  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hans wrote:Great build there Mike and some really good tips. Thank you. Hi Hans thanks for the encouragement  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
z8000783 wrote:budgie wrote: Is there such a thing as being TOO GOOD In a word, absolutely NOT. John Hi John, Thank you. Hi Budgie thank you for your comments,  I know you did not mean anything wrong, I appreciate you voicing your opinion. believe me my builds are not with out the odd blemish here and there,  and I agree with you it adds a little character to the ship. With the inks I am useing you can see the join of the planks, and the grain of the wood you can not see it very clearly on the photos. Don`t forget I am just an amature like you, I also make mistakes, I just expect high standards from myself thanks for the input Budgie  Kind Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
philjaps1 wrote:Really nice build Mike, interesting idea about using inks instead of paint, might have a play around with it my self Phil, Hi Phil thank you for your input  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
