Joined: 10/05/2011 Posts: 204 Points: 631 Location: Morayshire
Having read Andy's excellent recommendation for a beginners compressor kit, my question is what is the best airbrush to get, gravity fed or bottom feed? Also apart from the obvious what is the difference between the two types? Regards Bob Builds in progress
1/12 Spitfire (Deagostini) 1/8 McLaren (Deagostini) 1/16 Stuka (Hatchete) 1/16 Zero (Deagostini)
 Hi Bob As you already know i got both in the kit i bought,Mr T's link gives a good explanation i would just like to add this. Im also new to compressor airbrushes having used the propelant in a tin type in the past i did the 'goldberg Super Chipmunk' using cans [see pic i sprayed my canopy a see through blue but the rest was sprayed as shown],the gravity type airbrush has a fixed paint container of around 2 fluid ounces and is good for smaller parts and finer work,the bottom feed type generally have a larger glass pot paint holder that i find good for spraying hulls like my Yamato ,as the paint must be thinned down by 50% it can be hard to get a consistent colour match if you run out half way through.Also i have noticed that Tamiya's spray tin of Kure Grey tends to dry darker than mixed for airbrush at home,so i will have to respray all my model so far to get a consistant colour match.This is based on my experiences so far using the kit and will probably be shot down  by more experienced users on parts of the above but im learning too  ,hope this helps regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
kwakermad wrote:Having read Andy's excellent recommendation for a beginners compressor kit, my question is what is the best airbrush to get, gravity fed or bottom feed? Also apart from the obvious what is the difference between the two types? Bottom feed has the cup on the bottom and gravity feed has the cup on the top. Also to bare in mind is that you have a double action or a single action airbrush. A single action, You just press the button and it comes out at one speed but a double action it varies to how much you push the button down. An Iawata or a Badger are a couple of good makes. Best regards. Mark
Thanks for all the great advice,lots of food for thought. I really want to get hold of an airbrush kit before I make a start on my Zero and Stuka so as to try and do them justice. Regards Bob Builds in progress
