Straighten up & fly right Lewis ! (2nd pic added) Moved to Members Build Diaries. Options
Nick
#1 Posted : 27 June 2012 16:01:00
Rank: Amateur level 2
scottww86
#2 Posted : 27 June 2012 16:10:17
i think that looks pretty cool mate!
#3 Posted : 27 June 2012 16:28:00
Good idea for those that don't want a show car finish... get yourself some Vallejo Liquid silver if they have it.. great for dry brushing
Nick
#4 Posted : 27 June 2012 17:01:41
Thanks both of you.
I often use "Humbrol Metal Cote" and let it almost dry and with a bit of care you can push it into lumps.
I am just in the middle of stripping the paint off the exhausts and I shall repaint with Metal Cote in Gunmetal. Polish to the best posible and then apply blue, straw and a smidgeon of red to make it look as though it has done a few laps. I've done it over the DeAg finnish but F1 chimneys ain't silver
#5 Posted : 27 June 2012 19:08:01
Nick wrote:
Thanks both of you.
Here's a quick tip before you paint the exhausts.. take the paint back to the white maulding and then if you have a drimmel or simmilar use a brass wheel on it and you will be amazed at what effect you get.. looks like a flat steel but with a hint of "burnt gold" depending on the pressure you put on it.. only use the brass wheel buffer though.. I've done this to clean up mine and came accross the effect by mistake but wanted mine chrome for the finish
scotty2hotty
#6 Posted : 27 June 2012 19:41:21
2nd photo looks great too! BigGrin
Nick
#7 Posted : 27 June 2012 19:43:52
not quite sure where you are coming from but I feel sure practise will make perfect. I have the pipes back to "bare metal" so to speak so will probably have a go tomorrow.
P.S. If anyone reads this and intends to drill out the exhausts as suggested in another post (good tip Tengel!) dont just paint the resulting hole black, soot is not black.
#8 Posted : 27 June 2012 21:15:13
The pipes are made of a porcelain substance and are white when all the paint is removed
Exhaust
Heinzy
#9 Posted : 28 June 2012 08:48:30
[quote=Warthog if you have a drimmel or simmilar use a brass wheel on it and you will be amazed at what effect you get.. looks like a flat steel but with a hint of "burnt gold" depending on the pressure you put on it.. [/quote]
pics?
The Brawn Build
Wentworth Court Dolls House
The MP4/4 Build
[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
Nick
#10 Posted : 28 June 2012 09:49:21
Exhaust
The exhaust pipes are a strange material, not porcelain but perhaps a hard nylon. Strange to move away from ABS, perhaps production methods
I did think the location pegs are a bit vague to say the least, makes it a little trying to get the correct angle and distance from the engine.
#11 Posted : 28 June 2012 10:04:57
pics?[/quote]
Heinzy I'll try and either upload a few pictures or a video soon as I can BigGrin
Skiddy
#12 Posted : 28 June 2012 10:49:29
Exhaust
Smells of fibreglass when drilled
Nick
#13 Posted : 28 June 2012 10:55:35
Skiddy wrote:
Exhaust
Certainly not whitemetal as someone suggested.
This page was generated in 0.137 seconds.
