6 Pages <12345>»
Castos Victory Build Options
pierre50
#41 Posted : 26 June 2012 19:52:22
Hi Andre
Ok let me try, front of mast must have a flat 5mm wide 188mm long, then on the sides starting at the top where you made the 8mm square, it tapers to 3mm 127mm down. Check with scetch step 4
Hope this helps
PierreBigGrin
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
pierre50
#42 Posted : 26 June 2012 20:13:21
I'll be off work for a while, gonna give that scratch build idee of yours a go!
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
Castos
#43 Posted : 27 June 2012 08:00:05
Thanks Pierre
Am I correct that it must look like this test dowel that I did and that the surface between the top and sides will stay curved?
Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
pierre50
#44 Posted : 27 June 2012 08:21:58
The bottom pic starts at 8mm at the 8mm square and tapers up to 3mm, 127mm down
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
pierre50
#45 Posted : 27 June 2012 08:42:16
Hi Andre, crude but this might help
pierre50 attached the following image(s):
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
pierre50
#46 Posted : 27 June 2012 15:16:43
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
Castos
#47 Posted : 01 July 2012 16:56:59
Thanks Pierre.
Since my last post I have completed the Main mast, plus two of the yards. Must still do the Main Topgallant Mast, however, in which edition are the instructions for it, I have browse through to no 80 and cannot find it. Maybe I need some reading glasses LOL .
Photos to follow in the next post.
Cheers
Built: HMS Bounty
pierre50
#48 Posted : 01 July 2012 17:31:37
Hi Castos
Issues 72&73 you do the topmast and topgallant yards
Cheers
Pierre
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
Castos
#49 Posted : 03 July 2012 12:37:31
Thanks Pierre
Some photos as promised.
Wrapping rope around the mast with an idea borrowed from SoB, which makes it very easy to do as the rope does not become tangled and tension is maintained at all times. The device is used when making flies for fishing.
Completed mainmast with all the yards. Must still paint over the lower part of the mast.
Preparing the boat for painting the hull.
The hull is primed. Could not find grey or white, only pink available, so I made use of a Black which is used on all types of materials. A good thing about it is, that it matches the next colour above it, so there will be no leaking of the colours. Once dry it looks a lot like tar.
I have started the foremast. Slowly getting ahead and not in a hurry, as I have 10 days left before returning to Afghanistan.
Built: HMS Bounty
Hans
#50 Posted : 03 July 2012 13:22:33
Good looking build there Castos. Don't rush it, SOD might just have other plans with you. Keep it up and the pics rolling.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
pierre50
#51 Posted : 03 July 2012 13:29:18
Hi Andre
Like the rope binding idea, your build is coming on nicely BigGrin
Pierre
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
StefanDV
#52 Posted : 04 July 2012 09:03:55
Looking great Castos! The masts turned out very well!
Castos
#53 Posted : 11 July 2012 08:04:48
Good Day to All
My progress so far: Have partially completed the foremast, must still finish of the yards. The hull has been painted but needs to be sanded with a fine paper and then a final coat given.
The drydock is closed until September "due to a strike by the workers who have heard that new figurines will be arriving".LOL I will be returning to Afghanistan and will follow the threads from there.
Regards to all and keep up the builds.
Cheers
Built: HMS Bounty
#54 Posted : 11 July 2012 08:47:15
Hi Castos, nice work, good progressBigGrin Regards Mike
Hans
#55 Posted : 15 July 2012 17:35:57
She's looking great there Andre. Keep it up.
Rgds, Hans
Jesus-Belzheim
#56 Posted : 17 July 2012 18:00:31
Nice work there Castos ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
Castos
#57 Posted : 27 August 2012 14:50:07
12 days to go and the dockyard will be open again. I am looking forward to be at home and continue the build. Will be collecting the HMS Surprise and later on the Sovereign of the Seas when she is launched in South Africa.
Built: HMS Bounty
pierre50
#58 Posted : 17 November 2012 20:19:01
Hi André
Has there been any pics of the latest drydock opening?
Pierré
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
Castos
#59 Posted : 02 January 2013 10:00:22
Good Day All
Having trouble with internet here in Afghan Country. I have been trying to resize the photos in photobucket but due to the internet problems, I am struggling as it takes forever (a whole day to resize 1 photo).
Will post the photos when resized.
What has happened since my last post: returned home in September but did not build as I was away to Port Nolloth and then did maintenace at home. During December I completed until Issue 83, including the Booms, Mizzen Mast and fitted the gunport lids. Did some deck installation.
I have installed the Gallery windows and am having problems trying to find the right glue to glue wood onto it. I bought glue from the Hobby shop - Revell platic, but it does not work. Any recommendations?
At the moment working and will continue with the build in Feb.
By the way - A Prosperous New Year to all and may you continue to build.
Andre
Built: HMS Bounty
pierre50
#60 Posted : 07 January 2013 09:09:27
Hi Andre, nice to see you're still keeping up! Had same problem with glue, in the end I ended up with Genken contact adhesive!
Pierre
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
6 Pages <12345>»
This page was generated in 0.300 seconds.
