keel Options
steviegio
#1 Posted : 24 June 2012 17:57:54
Rank: Beginner Level 3
I need some help from the experienced builders out there. I have just completed the internal keel and when I look at it side on the top of the keel rises up towards the stern. I
This has the effect of making the top of the keel curve uop each end like a banana. At the centre point the bottom of the keel to the top is about 95mm whilst it is 100mm at the stern. Is this correct or do I have a duff part
steviegio attached the following image(s):
willie
#2 Posted : 24 June 2012 18:24:12
this is the camber of the deck fore and aft the other camber of the deck is port to starboard where the sides are low riseing in the middle ,quite normal
steviegio
#3 Posted : 24 June 2012 18:37:57
BigGrin Thanks
#4 Posted : 24 June 2012 21:41:49
hi steve,yep that's normal only the curve on the port and starboard is not there on this model,twarth of deck is flat.
z8000783
#5 Posted : 24 June 2012 23:04:38
Groups: Unapproved
Just make sure ALL the ribs are seated properly when you come to assemble them.
John
This page was generated in 0.124 seconds.
