LED Fitted. Options
davyp1
#1 Posted : 24 June 2012 11:04:18
Red Medal: Red Medal
Found a place for the P.C.B under the seat but still cant decide on place for battery and switch.9v battery required so it'll be 3 button batteries in series.Might seat them behind head rest but ill wait and see.
Picture 011.jpg (2,466kb) downloaded 232 time(s).
Picture 012.jpg (1,794kb) downloaded 189 time(s).
Picture 009.jpg (2,463kb) downloaded 198 time(s).
schueyking
#2 Posted : 24 June 2012 12:23:50
BigGrin Good work mate!ThumpUp
ChrisBigGrin
#3 Posted : 24 June 2012 13:14:02
Hi Davy good stuffBigGrin Reards Mike
firefighter
#4 Posted : 24 June 2012 17:18:02
it looks good iv got 1 to put on mine but im going to ue a 9v square battery so it will last longer thinking of making a battery compartment under my stand with a switch at the back
goonerscott89
#5 Posted : 24 June 2012 18:50:46
i don't think you can just wire up an LED to a 9v Battery, it will just burn the LED out.
#6 Posted : 24 June 2012 18:58:36
You can get 9v LED's from Squires electronics, or just wire a resistor in between the LED and the switch.
Roy.
davyp1
#7 Posted : 24 June 2012 20:58:28
Hello all.
Its a flashing LED with speed adjust available from maplins electronics.9V square battery will power but the size of it may be a problem if you want all electronics to be kept inside.You will have to build the circuit by soldering.The components required come in a kit.Price approx £7.
This page was generated in 0.114 seconds.
