Front wing test Options
S2ksean
#1 Posted : 22 June 2012 18:33:06
I've got a spare front wing that I picked up cheap on eBay so i decided to use it as a test to see how the clear coat I've got will looked when sprayed on
Will post pics shortly
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#2 Posted : 22 June 2012 19:00:19
Be careful what type of clearcoat you use, because the Mr Hobby B501 gloss aerosol shown is an aqueous type, which Tamiya aerosols are not, though Tamiya's X22 clear gloss pot version is aqueous and can be airbrushed/sprayed or brushed.
The Tamiya aerosol may work, but I would apply in very light coats allowing it to dry between to prevent solvent build-up and it eating into the silver paint/printed livery etc.
S2ksean
#3 Posted : 22 June 2012 19:00:57
Pictures as promised
These have five small coats of clear coat on them
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#4 Posted : 22 June 2012 19:04:25
Cheers Tom thanks exactly what i did. This is what I used
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
goonerscott89
#5 Posted : 22 June 2012 19:05:03
How do you feel about them?
S2ksean
#6 Posted : 22 June 2012 19:08:08
I think it looks really good. I'm just in the middle ov putting the front wing together then I will put it next to the other standard wing and post the pic
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#7 Posted : 22 June 2012 19:40:06
These r the best pictures I could get
Let me know what ya think peeps
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
davyp1
#8 Posted : 22 June 2012 20:39:38
Red Medal: Red Medal
Looking good.Is this the solution to the colour problem do you think?
How does it match with the side pods?
S2ksean
#9 Posted : 22 June 2012 20:52:11
I don't know if this the solution but I'm seriously considering doing the whole lot when it's finish cause I think it looks really good and as long as u take ur time and dont spray too much too quick it will be fine. I haven't got the side pods yet they r in my next issues that turn up but when there do il stick up a pic.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#10 Posted : 23 June 2012 13:54:20
I think I might spray the underside of the Wong as well to give it a shiny carbon effect il post the pics after
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
only1ianuk
#11 Posted : 23 June 2012 14:13:33
I must admit it does look pretty good. Doesn't look like it makes a difference on the silver in the pictures but the red definately comes up good.
Not too sure i want to be spraying the model incase i mess up and ruin it!
S2ksean
#12 Posted : 23 June 2012 14:34:16
The only real difference it makes is added protection and a tiny bit shinier. Also be a lot easier to clean when it gets dusty.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#13 Posted : 23 June 2012 18:22:48
Underside clear coated
Not made much difference but it's abit shinier so it dose look better. Don't matter much as u won't see it under the car lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
schueyking
#14 Posted : 23 June 2012 21:13:11
BigGrin Very good! How many coats did you use and how long between coats? I am VERY new to this spraying malarky!LOL LOL LOL
S2ksean
#15 Posted : 23 June 2012 21:26:18
I done a very thin coat every 15-20 mins. Total of 5 coats
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
schueyking
#16 Posted : 24 June 2012 12:18:16
BigGrin Thanks for the info mate!ThumpUp
S2ksean
#17 Posted : 24 June 2012 18:33:42
Your welcome
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Nick
#18 Posted : 30 June 2012 09:02:14
Rank: Amateur level 2
I have just taken my chimneys back to "bare metal" and the only thing that removed the paint was acetone. Presumably this is the same silver as the rest.
Also way back I ordered a spare front wing and coated it in "Klear" as yet it does not show any signs of deterioration. As an aside it does not solve the colour differnce mentioned elsewhere.
After the Klear had dried I just polished it with a spectacle cleaning cloth and then assembled.
Just note I only post this in the hope it may offer some clues. Work on the assumption I am not always right and I could be wrong again!!!!!
#19 Posted : 30 June 2012 10:34:02
Nick wrote:
[Just note I only post this in the hope it may offer some clues. Work on the assumption I am not always right and I could be wrong again!!!!!
Nobody is wrong - just diferent.
Thanks for the info though. I've used Halfords clear lacquer on a spare front wing (pics posted elsewhere on the forum) and it works a treat - nice and glossy.
Roy.
#20 Posted : 30 June 2012 11:28:07
Roy.
But not on the silver I hope Roy!!!???
This page was generated in 0.368 seconds.
