Missing pins in Issue 17 Options
Jinnai
#1 Posted : 22 June 2012 08:32:31
Just a heads up for the other Aussies on the forum.
From several sources now (and my own issue) it's been revealed that the pins are not included in Issue 17. These (if you follow the instructions) are required to secure the framework and the first gun decks to the hull.
While I can do without them (I will use spares from my Endeavour), many of you might not be able to.
For some reason we have parts for a 12 pounder included? While I've read that this is to cover the supposed 12 pounder from Issue 14, Issue 14's parts don't show we were supposed to get a 12 pounder, nor does the official build.
Could Admin please advise as to who we need to contact for missing parts in Australia?
Thank you.
EDIT: I finally noticed in the official build that 14 should have had a 12 pounder, it just didn't show the pictures of the parts and was a small mention.
We still didn't receive the pins though. :)
StefanDV
#2 Posted : 22 June 2012 08:45:42
In South Africa we also didn't get the pins for the deck. I just cut pieces of wire.
I suppose 5mm panel pins from your local hardware shop may also do the trick.
admin
#3 Posted : 22 June 2012 11:54:35
Hi all,
For Australia, it's best to use the Customer Service section on our Facebook. You can email, call or Facebook them. See link here:http://www.facebook.com/pages/Model-Space-Australia/338142669559575
Thanks,
Admin
This page was generated in 0.130 seconds.
