56 Pages «<3435363738>»
#701 Posted : 20 June 2012 18:17:49
ISSUE 42
I then fitted the parts with care as per the instructions using my small bars:-
Please note the parts are fragile, and make sure you have a 1mm recess in the existing fitted parts to accept the new parts
#702 Posted : 20 June 2012 18:21:21
ISSUe 42
This is how she looks now after build 42:-
Questions and comments welcome,BigGrin thats all for this week Regards Mike
mark 2
#703 Posted : 20 June 2012 19:32:26
Hi Mike.
Starting to come together now.
Looks fantastic.
Keep up the great work.
Best regards.
#704 Posted : 20 June 2012 20:25:40
mark 2 wrote:
Hi Mike.
Looks fantastic.
Best regards.
Hi Mark, It certainly is, BigGrin Thank you for your nice comments,Reagrads Mike
Jesus-Belzheim
#705 Posted : 20 June 2012 23:49:58
Hi Mike
That is looking very good ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#706 Posted : 22 June 2012 00:35:44
Jesus-Belzheim wrote:
Hi Mike
Thanks Peter it is very nice of youBigGrin Regards Mike
Silent_Running
#707 Posted : 22 June 2012 01:04:12
Superlative work as always Mike, I'm watching with interest. By the way, you've done a cracking job on the planking, top drawer.
ThumpUp BigGrin
#708 Posted : 22 June 2012 09:17:50
ThumpUp BigGrin
Hi Glenn thank you for your words of encouragementBigGrinmuch appreciated. Regards Mike
#709 Posted : 27 June 2012 17:17:51
ISSUE 43
Hi Team well the week has flown by again, and this week we received, some more wallcovering:-
#710 Posted : 27 June 2012 17:20:56
ISSUE 43
I think there is an error in the instructions this week, in the Blue panel it says to us PVA to glue the brass:-
#711 Posted : 27 June 2012 17:23:15
ISSUE 43
When before it when we were fitting wallcovering it said (ISSUE40):-
So I have used the latter instrucyions for my build this week.
#712 Posted : 27 June 2012 17:30:38
ISSUE 43
These are the pieces we need this week:-
176 the two disc parts from fret 1001, Issue 40
169 rail piece from fret 1021, Issue 41
and the parts from the fret you have received today:-
#713 Posted : 27 June 2012 17:35:44
ISSUE 43
I cut out all the parts I needed for the build this week, removed all the burrs from the pieces with a file ( this is very important as th pieces fit into slots with exact tolarences )here they are:-
GOOD NEWS THE WALLCOVERING WHICH WILL BE MORE PROMINENT HAVE EYEBROWS so no need to make your own.BigGrin
#714 Posted : 27 June 2012 17:42:13
ISSUE 43
I then continued to follow the instructions.
The fitting of the 26 brackets is very fiddly and time consuming, please use a good pair of tweezers, and dry fit the bracket into the slot before you glue it:-
#715 Posted : 27 June 2012 17:49:06
ISSUE 43
Now to fit the very very small parts the bolt (175) and the eyebolts x 3 (174):-
#716 Posted : 27 June 2012 17:53:00
ISSUE 43
At this point I fitted the first wallcovering with the EYEBROWS, again dry fit unill your happy then glue it:-
#717 Posted : 27 June 2012 17:55:40
ISSUE 43
Finally I fitted the 2 discs over the portholes:-
#718 Posted : 27 June 2012 17:59:23
ISSUE43
Thats all for this week, thanks for looking in,questions and comments welcomeBigGrin This is how she looks at the moment Regards Mike
harty
#719 Posted : 27 June 2012 18:37:32
Supberb build quality as usual young MichaelLaugh BigGrin
jonny7england
#720 Posted : 27 June 2012 19:56:47
Brilliant mate, fantastic build!! Love
Guest (12)
This page was generated in 1.078 seconds.
