2 Pages <12
anchor Options
dtgray
#21 Posted : 28 April 2010 10:20:47
Your right, the new ring look far better, I think I'd do the same now.
David
Mald
#22 Posted : 28 April 2010 10:40:39
Changing the Anchor Ring !!
I decided to go for a large Anchor ring , After opening up the Anchor kit i to thought the ring looked a little small , I made a new ring so the old one fitted inside , that give me the perfect Dia . While i was busy I made up all Four rings together .
All the photos and reference points have been a great help , I now check as many photos of Victory as i can , and will continue to do so before i assembly any of my Model of HMS Victory . Thanks to everyone on the forum for your amazing tips and reference points .
pamlupo
#23 Posted : 28 April 2010 15:56:47
how big is the new ring ?
mavrickandgoose
#24 Posted : 28 April 2010 17:11:39
i remade the anchor ring this afternoon,to make it a bit bigger. i used the core of co-ax cable. which i stripped out and then bent into a circle around my knife handle. i will be doing the rest this weekend. probably putting the puddening on with fishing line and the seasing on with white thread.
steve
Mald
#25 Posted : 28 April 2010 18:24:36
The External dia is 14mm ,Ideal size for the scale of this Anchor
Zeptrader
#26 Posted : 28 April 2010 18:51:28
Thats so much better, well done Mac:)
baz
#27 Posted : 28 April 2010 19:55:42
Rank: Beginner Level 3
The bigger anchor ring def looks alot better, think i'll be changing maine aswell. i'm glad I have joined the forum as i'm guessing there are going to be many modifications to the kit
Jamie
#28 Posted : 28 April 2010 20:39:13
Oh yes that looks alot better macmedal. Any idea what diameter is?
I wish I were a glow worm,
A glow worm's never glum,
'Cause how can you be grumpy?
When the sun shines out ya bum!!
Zeptrader
#29 Posted : 28 April 2010 21:22:14
#30 Posted : 28 April 2010 22:21:10
Fantastic work Mac, 14mm yes! I will do the same as you
Cheers
timebob
#31 Posted : 28 April 2010 22:38:48
thats better cap what did you use & how did you get it round?
Macmedal
#32 Posted : 28 April 2010 23:49:16
I used copper earth wire from lighting cable. I took a long strip and wrapped it around a circular object which was the correct diameter (approx 12mm internally) then cut it at the cross over point.
14mm external sounds about right for the 1:84 scale as Mckays book for 1/96 bower anchor is 12mm.
ArtfulBodger
#33 Posted : 29 April 2010 10:34:36
Macmedal
What a brillant idea, copper wire, I'm impressed and will follow suit if you don't mind a little plagerism.
ArtfulBodger
Previous Build:
HMS. Bounty
tom.ganc
#34 Posted : 30 April 2010 11:33:17
Hi there
I've just received 2mm rope from cornwall model boats. It is really nice but how to make it white?
Tom
#35 Posted : 30 April 2010 14:04:31
tom, the rope comes white from cornwall models, or bleach existing rope.
tom.ganc
#36 Posted : 30 April 2010 14:38:15
Well
Mine came in brown ish colour so I need to bleach it I guess.
What's the product code for this rope anyway?
Thanks
2 Pages <12
