pierre50 wrote:Hi Stefan, read somewhere on the forum, after sticking the tape you first seal the tape with the yellow and then you do the black, I've tried it and it works just fine, Pierre Yes, that is what I did, as Karl suggested it to me...I had a tiny bit of bleeding but I was able to touch up the areas using a fine brush and a very steady hand (my daughter's) You shouldn't have any trouble remedying it Stefan...You are doing great though mate!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi Stefan Looking realy nice. Keep the pictures coming Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Hi Gentlemen, Thanks so much for your support, you've got no idea how much it means to me. I feel blessed to be part of a community such as this. The painting of the stripes and gun-ports is now complete:  Little touch-up still needed, but largely there:
Look perfect to me.
Feeling good?
Should be.
John
Joined: 11/09/2011 Posts: 227 Points: 677 Location: Heidelberg South Africa
Looking good Stefan! Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Thanks John & Pierre. Nothing like a bit of success and some progress to lift the spirits. Decided to copper-paint the hull before tiling - got the 1st coat on last night.
Brilliant stuff, Stefan, looking good. Keep it up. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Great paintingjob there Stefan, It looks very good
Thanks Hans & Peter! Finished the painting of the hull last night:   Now the copper tiling starts....
I have just started on the tiling, looking forward to seeing your progress.
John
Hi stefan. Looking great mate. like the paint job. Look forward to seeing your copper tiles are you going deag way or following the water line with cut tiles Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Looking good Stefan Like your stands, brilliant! Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Doing a very nice job in deed Stefan!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 04/06/2012 Posts: 19 Points: 57 Location: Pretoria (SA)
Your paintwork is stunning, your build looking very good. I like your stand, good idée to protect your hard handwork. Built Albatross, build in 1982 from plans. Hms Bounty, build in 1987 from plans. Duyfken,build in 1991 from plans Oosterland, build in 1998 from plans
In the meantime. HMS Victory (Deagostini) 2011 Building MFV63 fishing trawler from plans. HMS Mayflower (Kit)
Wish list Still planning.
Thanks so much for your kind comments all. I finally found enough courage to start the tiling. The battens for the topmost layer of tiles fitted.  Two rows of tile fitted to the starboard side. (The glue still needs to be cleaned off)
Hi Stefan DV, Great build Stefan,paint work looks neat thanks for sending your pictures Regards tf64 Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Welcome to a long tedious task. The tiles are a time consuming job, but look really good when there all on! The copper paint looks like a neat job, you will find that painting the hull copper will pay dividends in the long run. I look forward to seeing the finished hull, take your time and all will be well. All the best Steve..
Goodluck with the tiling Stefan :) Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Thanks tf64, Steve & Pierre! Tonight I hope to get cracking on the tiling of the keel, but first I have to make sure that the glue I'm using is strong enough. Had a couple of scares last night with tiles coming off, but it turned out to have been 2 tiles on top of one another!
Joined: 05/09/2010 Posts: 123 Points: 358 Location: Valhalla, Pretoria
Nice build Stefan. Will be watching closely when you get to start the rigging. Cheers Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
Guest (10)
