HMS Daring meets USS Abraham Lincoln Options
#1 Posted : 14 June 2012 16:49:05
For the second time in a matter of weeks Britain’s most hi-tech warship joined forces with the world’s most potent surface ship: a Nimitz-class nuclear-powered aircraft.
In the foreground is USS Abraham Lincoln, her deck crammed with 35 F18 jets of various configurations, three Hawkeye AWACs early warning aircraft, three EA-6B Prowler electronic warfare specialists and six Seahawk helicopters (plus a seventh hovering over the stern).
As well as an impressive demonstration of ‘parking’ by the deck handlers, this only comprises a little over half of Carrier Air Wing Two which are permanently assigned.
In the background, HMS Daring, the Royal Navy’s leading air defence destroyer, and, if they were airborne, capable of tracking every single aircraft in Carrier Air Wing Two simultaneously and then some...and then some more, and a few more again...
Sandwiched between the two in the Arabian Sea is the oiler USNS Guadalupe.
USS Lincoln is carrying out combat flight missions in support of Enduring Freedom, codename for the US mission in Afghanistan, as well as wider maritime security duties.
Daring’s days in the region are drawing to a close; her replacement, HMS Diamond, has sailed from Portsmouth to take over in a few weeks time.
Since departing back in January, Daring has exercised with four US carrier strike groups: the Lincoln (twice) and the Carl Vinson and Enterprise (once a piece).
bdurso
#2 Posted : 24 June 2012 03:59:06
I spent about two years on the Lincoln, around 2006-2008 or so. She is looking pretty weathered in the picture there.
#3 Posted : 24 June 2012 10:53:06
Wow, do you have any photos you can share with us?
bdurso
#4 Posted : 25 June 2012 12:16:18
I think I do have some at home. I am currently in Japan on business, but when I get home if I can boot up my computer I had when I was on deployment I should be able to provide a few pictures. I also snapped about 100 pictures of the 1/10th scale Yamato at the Kure Naval Museum two weeks ago, and if I can find an image host for the pictures (each around 3-4mb) I will link them. Might be helpful for our fellow builders tackling the Yamato.
Cheers!
Brad
#5 Posted : 25 June 2012 12:58:33
That would be fantastic ThumpUp
This page was generated in 0.098 seconds.
