 Rank: Pro     Groups: Registered
Joined: 09/08/2011 Posts: 399 Points: 1,168 Location: Hertfordshire
Just wondering if any of you guys have had an issue with over spray? Picked up my latest issue from the news agent and there was slight "rocket red" over spray on the silver part of the body work I'll get a pic up later to show you what I mean, just seeing if any one else had noticed this? Cheers p.s 7th different winner at the 7th race this weekend? The Brawn BuildWentworth Court Dolls HouseThe MP4/4 Build[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
Joined: 27/05/2011 Posts: 256 Points: 774 Location: barrow in furness
i havent noticed any on mine mate. will compare it to your pics once youve put one up. im hoping for another storming drive from button this weekend! If at first you don't succeed........skydiving is not for you!
Heinzy wrote:Just wondering if any of you guys have had an issue with over spray? Picked up my latest issue from the news agent and there was slight "rocket red" over spray on the silver part of the body work I'll get a pic up later to show you what I mean, just seeing if any one else had noticed this? Cheers p.s 7th different winner at the 7th race this weekend? This will probably be covered with the decals so I wouldnt worry about it to much but until we see a picture, can't really tell...
Here's a pic of the part in question Although it is quite hard to see in the pic, most of it with be sanded off as part of the fitting but there will still be a part of it on show Just thought I'd bring this to eveyones attention, make sure no one else had the same problem! The Brawn BuildWentworth Court Dolls HouseThe MP4/4 Build[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
Joined: 25/03/2011 Posts: 12 Points: 36 Location: essex
Hi Will that not come off with some T cut polish ..?? JC.. Hurry up with my mag !!!!!!
T cut will take the silver off so i wouldnt try that! just send it back and get a replacement. mine isnt like that! If at first you don't succeed........skydiving is not for you!
Defo get a replacement for that
Joined: 05/07/2011 Posts: 126 Points: 354 Location: Withernsea East Yorkshire
Might be hidden once that bit of side cowling is fitted to the main chassis? Just an idea! MeffMan
