Hi Mark thank you for your kind comments  it is appreciated  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 40 Hi Team, this has turned out to be a tricky build this week, as I feel Hachette have added a little extra without explaining it in the instructions, I will explain soon. This is what we received this week;- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 40 This is the wallcovering we received this week:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 40 I cut the parts from the fret filed off the burrs as usual, I then bent the parts using the edge of a conti board, as per the instructions:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 40 Then I came to fit the parts, and the part was longer than the wood it was designed to fit. I looked at the photos in the instructions, and then I spotted what I think is an added infill, take a look:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 40 But no where does it tell you to fit this item, so I used a piece of second planking because the infill needed to be 1mm thick here are the photos of my work:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 40 And the final photos, I do feel someone somewhere has not added the insructions on how to include the infill  Questions and comments welcome as usual  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Hi Mike Veni Vidi... and solved it Good job
Looking good mike. With the bulkheads she starting to look like a ship. Are you looking forward to the paint spraying. I fpound that was the easyest way to do my bismarck. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
MWG wrote:ISSUE 40
But no where does it tell you to fit this item, so I used a piece of second planking because the infill needed to be 1mm thick here are the photos of my work:- Hi Mike. I see what you mean  . I think that someone at hatchette was on the sherry that night  . When i get to that i may wait awhile and see what the next few partworks bring although i think you might be right. I also think that there is anouther wall that leads of that. This one will be on my next delivery. Best of luck and regards to you Mike. Mark
Jesus-Belzheim wrote:Hi Mike Veni Vidi... and solved it Good job Thank you Peter  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ian smith wrote:Looking good mike. With the bulkheads she starting to look like a ship. Are you looking forward to the paint spraying. I fpound that was the easyest way to do my bismarck. Ian Hi Ian yes the spray option will be the best but first white squadron putty  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
mark 2 wrote:MWG wrote:ISSUE 40
But no where does it tell you to fit this item, so I used a piece of second planking because the infill needed to be 1mm thick here are the photos of my work:- Hi Mike. I see what you mean  . I think that someone at hatchette was on the sherry that night  . When i get to that i may wait awhile and see what the next few partworks bring although i think you might be right. I also think that there is anouther wall that leads of that. This one will be on my next delivery. Best of luck and regards to you Mike. Mark Hi Mark it does appear a bit of a lottery  But I am sure it is nothing we can not handle eh?  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 41 Hi Team this week we have a break from Brass wall covering, and this is what we received:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 41 We put the Brass part away untill another time. I cut out the wooden parts, and went to assemble them as per the instructions but I found a few challenges and had to trim the parts to fit how the instructions called for, you will see I had to trim a piece of wood off the spacers with the tongue:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 41 But all is well in the end. I do feel Hachette are putting us through an IQ test with these instructions, sometimes I feel they think we should know what is coming next  Questions and comments welcome. Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 21/04/2012 Posts: 747 Points: 2,233 Location: Tokyo, Japan
Hi Mike! You've done good job!  I think this type model is like puzzle, too.  By the way I also think Japanese HMS VICTORY modelers are happy to be able to refer to ModelSpace. Because they can know what parts will come next all 120 weeks. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
Yutaro HONMA wrote:Hi Mike! You've done good job!  I think this type model is like puzzle, too.  By the way I also think Japanese HMS VICTORY modelers are happy to be able to refer to ModelSpace. Because they can know what parts will come next all 120 weeks. Best Regards, Yutaro Thank you Yutaro san for nice comment  you are right about the puzzle. I am glad the Modellers in Japan refer to the Modelspace, we are very lucky to have such a great bunch of members who are very knowledgable Best regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 42 Hi Team this week we continue with the wallcovering, but this time using very thin ply (1mm)This is what we received:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 42 Taking the parts I cut them from the fret and prepared them as per the instructions:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (11)
