4 Pages «<234
Display Case Options
goonerscott89
#61 Posted : 05 June 2012 12:08:08
schueyking wrote:
goonerscott89 wrote:
Hi all
Why not make one your self instead of buying 1.
sorry about the quality of the photo.
Whose is this case??? Damn impressive!!!Drool Drool
Hi, Thanks for the comment, I built it myself. I thought instead of spending 80 odd quid on one from ebay I would rather build one myself and probably save a few quid plus have it to the spec that i want it.
goonerscott89
#62 Posted : 05 June 2012 14:00:51
Hi all
Welcome to the forum mate, That looks stunning.
Care to share how you built it?!
Thanks,
Firstly I got the glass cut at a local glass cutting company. The 4mm glass was cut to 2 x 700mm x 300m, and 2 x 300mm x 300mm cuts. I stuck the glass together with clear silicone using right angle clamps to hold them in place, leaving it 48 hours to set and dry. Then I got black glass spray paint and sprayed the back side of the glass. I used 15mm Ali corner to stick down the side of glass. it also keeps the glass at right angles.
For the base i got 3mm hardboard cut to 4 x 730mm x 330mm. then 18mm x 40mm sawn timber. I stuck the saw timber around the hardboard then stuck another piece of hardboard on top to sandwich the timber. The base should then be 24mm thick. I bought 3D textured carbon fibre vinyl from ebay, using a hair dyer to soften the vinyl then peeling and sticking it to the top of the base. The top is the same principle apart from drilling 5 holes into the bottom of the top Base to put the LED's in, and putting the carbon fibre vinyl on both top and bottom of the top base. I also left the top hardboard of the top base unstuck so I could access the LED's.
For the top and bottom base I used 25mm x 15mm Ali corner to run along the edges. I stuck it down using no-nails adhesive, but for the top base I left the back piece of Ali corner off and screwed it instead. This is so I could slide the top hardboard out to access the LED's.
As for the Vodafone Mclaren Mercedes sticker I ordered it from a website, size 400mm.
I hope this helps anyone who wants to build their own display case.
Any more questions please ask.
Skiddy
#63 Posted : 05 June 2012 15:26:12
Hi all
Maybe from here BigGrin had all the design... sizes... instructions for anyone to copy on here, but due to the colour problem I was about to exit the whole thing as there was nothing coming back from admin so deleted it, especially when people that use this site for a business copy your design and make money from it ( not goonerscott ) but you know who you are !!
case 001.JPG (2,596kb) downloaded 98 time(s).
goonerscott89
#64 Posted : 05 June 2012 15:56:05
Skiddy wrote:
Hi all
Yes Skiddy this did inspire me to make my own Blink
Senna94
#65 Posted : 05 June 2012 20:20:17
Hi all
Thanks,
Fantastic thanks alot for your insight mate.
Care to share where the sticker, care to share where you got that from?
I plan on making something similar.... not for a while yet but its given me some great ideas.. thanks alot.
Building the McLaren MP4-23
goonerscott89
#66 Posted : 05 June 2012 23:52:55
Hi all
Thanks,
From this website in the 400mm size
http://www.cargraphicsan...en_Mercedes_Sticker.html
Senna94
#67 Posted : 06 June 2012 09:57:06
Brilliant Cheers mate, Much appreciated.
4 Pages «<234
This page was generated in 0.155 seconds.
