minicraft powertools Options
#1 Posted : 27 April 2010 21:13:00
Can anyone help, I need to find a website that deals with minicraft powertools,I have googled it,and have had no luck.
Kan
#2 Posted : 27 April 2010 21:15:02
Rank: Amateur level 2
Heres one i havent tried it myself yet but they seem to have a good selection tinytools
dtgray
#3 Posted : 27 April 2010 21:17:45
Here's another one www.hobby.uk.com
David
#4 Posted : 27 April 2010 21:24:37
I think Minicraft vanished off the map a while ago, here's a few alternatives
http://www.proxxon-direct.com/
http://www.modellersmate.co.uk/products.htm
http://www.expotools.com/
pamlupo
#5 Posted : 27 April 2010 21:37:35
Hi
What are mini tools?
PamHuh
dtgray
#6 Posted : 27 April 2010 21:43:13
Small power tools. Like Dremel etc BigGrin
David
pamlupo
#7 Posted : 28 April 2010 21:34:59
thank you
Do we need them for the build
pam
budgie
#8 Posted : 29 April 2010 00:38:13
Cool
pamlupo wrote:
thank you
pam
u can get mini hand drills (size of a pen)instead of mini electric rotary drill
u can use sandpaper/wet & dry with suitable size block instead of sanding disc attachment of various shapes sizes
some people prefer hand tools as feel they have more control
electric rotary tools are quicker at doing the same job but might need getting used to using them (oops slipped oops pressed too hard )
#9 Posted : 29 April 2010 09:54:55
The use of mini power tools aid the build, but are not an essential requirement to building this model.
Mike Turpin
#10 Posted : 29 April 2010 10:34:33
budgie wrote:
Cool
pamlupo wrote:
thank you
pam
Choice of tools is definitely 'horses for courses'. When I started my HMS Halifax some years ago, my wife desparate for a christmas present idea bought me a Dremel power tool with the usual accessories. As Budgie suggests it took some getting used to and to avoid slips the hand drill was often a more controlled option.
This winter I decided that I really ought to get organised to finish first Halifax and then Bounty and included a vertical drilling stand for the Dremel in my Christmas list. I also bought the relatively large and heavy hand vice so I could position pieces accurately. In the picture, I have set up a circular piece for an end hole.
This has given me so much control over positioning holes accurately and also drilling metal pieces was never easy by hand. I guess the consistent high speed of the drill is important.
AND THEN ... ALONG CAME VICTORY!!
So I now have three kits on the go plus Cutty Sark hidden in the attic!
Once I have finished the deck fittings on HMS Halifax, which I now regard as my training project before Victory, I will be moving on to the masts and spars. I really admire some of Zeptraders earlier posts showing his re-fitting on Bounty but decided that this could be really time-consuming using hand sanding. I tried sanding using a normal electric drill clamped horizontally but again for me, I found this awkward,
Therefore the birthday fairy was persuaded to deliver the ultimate power tool this week in the shape of the Proxxon DB250 mini wood-turning lathe and a set of 5 mini-chisels.
So far it has taken me several hours on the web looking at wood-turning video lessons and about an hour of practice. The results are on top of the motor unit.
I am justifying this in terms of speed and accuracy.
In my opinion the mast profiles for Halifax get quite complicated and you need to turn down from large to quite small diameters.
This last picture shows the tapering exercise based roughly on part of the topmast profile which includes the narrow bit towards the end. Not bad, I thought for a first ever attempt at a craft I have always wanted to try my hand at .. wood turning.
As a footnote: the birthday fairy (oops SHMBO) has decided that a fitted spice rack in the kitchen with turned vertical pillars would look really nice!! I did suggest after Victory but the outcome was .....)
Mike T
#11 Posted : 29 April 2010 10:41:52
Seems you've caught the miniature wood turning bug, I did warn you LOL
A sprung Caliper set is a very useful addition for getting internal/external diameters spot on.
Mike Turpin
#12 Posted : 29 April 2010 10:43:43
I know I should have listened!!!Mellow Mellow
#13 Posted : 29 April 2010 14:18:52
thank you gents for www sites very useful,have a look in my victory build you can see the powertools at the rear of my table, I did not realise I would start a powertool debate,by the way minicraft have been re-named by the look of it,zircon appears to be the new name.my main tool is the powerdrill,with the right attachments you can sand,grind,polish,cut wood,and drill of course.but rightly so these are not mandatory,but i do get a lot less cuts and bruises,and i think a higher standard of workmanship,finish.
Mike Turpin
#14 Posted : 30 April 2010 11:05:30
Following on from what Tomick said about sprung calipers I had a look at the above site and found some. Also they do a modelling tool kit which seems to have some different items to those we are expecting to get as part of the build and coincidently covers a shopping list I was beginning to build up such as a proper cutting mat and a mini plane etc.
So I have placed an order with Tinytools and will let everyone know what their service and products are like when it arrives.
Mike T
Mike Turpin
#15 Posted : 04 May 2010 21:18:08
I promised to report back on my TinyTools order.
The calipers are pretty standard and a good buy. The £19.99 cutting tools kit was, I would say, what you might expect at the price. Good selection of knives and blades with a mini plane, sharpening block and a free cutting mat. At the moment the jury is out on the plane until I start to use it. I expect I could have got a better one separately, might still be visiting Maplins but now have a better idea of what I can expect.
The service was good. Placed the order at midday Thursday, got a dispatch notification e-mail on Friday p.m. and delivered today Tuesday, which considering there was a bank holiday was not bad!
Mike T
Mike Turpin
#16 Posted : 04 May 2010 21:28:47
I was looking at the picture of your workspace. The drill and stand is clearly identifiable and I assume the unit on the right is a circular saw table(?) but it is difficult to see the middle tool, in the shadows a bit, any info and what make is the saw?
Mike T
ccarlos
#17 Posted : 04 May 2010 21:41:22
i got mine from ebay....and for a third of the price of dremmel....
lets c how long will they last
heheCrying
on the bench
Endeavour Long Boat - awaiting paint delivery and some power tools to hit the next stage.
HMS Victory - Same situation has everyone else, grumpy till the next issue gets delivered!
Carlos Carlos
#18 Posted : 05 May 2010 22:09:01
mike,they are all minicraft, saw table,sander,drill andstand all from e-bay,I also have a black and decker rotary sander with loads of attachments, only use that on the big jobs,brilliant tools minicraft and fairly hard to obtain.
cham-oo
#19 Posted : 13 September 2010 16:18:20
Rank: Amateur Level 1
Hi all,
What opinion do you guys have on the Unimat-1 Classic 6-in-1. Seems like a good starter set.
Or do you prefer Dremel tools?
Both makes are available locally, but quite pricey!!
Jacques
Jack Sparrow
#20 Posted : 13 September 2010 16:20:27
cham-oo wrote:
Hi all,
Jacques
I use the Dremmel as I have limited work space and it does everything I need to do. BigGrin BigGrin
This page was generated in 0.174 seconds.
