anchor Options
timebob
#1 Posted : 27 April 2010 19:50:22
Rank: Beginner Level 3
BigGrin hi ship mates just done the anchor what do you thinkBigGrin
mavrickandgoose
#2 Posted : 27 April 2010 19:52:24
i dont know! i can only see a red cross in a box!! any idea how to get rid of it?? and get the picture
mavrickandgoose
#3 Posted : 27 April 2010 19:54:21
got it now! nice one, i was being a computer biff!
Jamie
#4 Posted : 27 April 2010 19:55:56
Looking good timebob looking good ThumpUp
What thickness is the rope you've used??
I wish I were a glow worm,
A glow worm's never glum,
'Cause how can you be grumpy?
When the sun shines out ya bum!!
timebob
#5 Posted : 27 April 2010 19:57:34
2.50mm but i might change it, looks a bit big
Jamie
#6 Posted : 27 April 2010 20:12:04
Cheers timebob, the reason why I ask is I'm gonna change the rope that was sent in with the anchor to the very one you've used but I wondered if 2.5mm would either be big enough or to big and to be honest after seeing yours I'm still not sure Confused Blink
timebob
#7 Posted : 27 April 2010 20:16:10
after pudding the anchor ring you got a job getting rope through. it will only go through the
ring once.
Jamie
#8 Posted : 27 April 2010 20:21:05
Actually Huh I've just had a look at an anchor which is on the victory now. Now, I know it is a replica anchor but the dimensions should be roughly the same, yes?, and assuming they are it looks like the ring is to small and not the rope being to big!! Glare Blink
mavrickandgoose
#9 Posted : 27 April 2010 20:39:07
i see what you mean it is a fair old ring!!
timebob
#10 Posted : 27 April 2010 20:43:16
looking at the anchor in the pic the ring they give us is too small compaired too the size of the anchor.
Jamie
#11 Posted : 27 April 2010 20:49:18
Take a look at this one too.....
Ring definately looks bigger.
dtgray
#12 Posted : 27 April 2010 20:57:36
Good work BigGrin
David
tom.ganc
#13 Posted : 27 April 2010 21:37:13
Hi there
Great job with the anchor.
What kind of rope is it and where can I get it from?
Thanks
Tom
pamlupo
#14 Posted : 27 April 2010 21:41:09
Hi
It looks really good. I need to get mind going
Pam
timebob
#15 Posted : 27 April 2010 23:29:53
rope is 2.50mm from cornwallmodels www.cornwallmodelboats.co.ukBigGrin
Zeptrader
#16 Posted : 27 April 2010 23:43:52
I think the rope thickness is pretty good, but the ring as you say is a little too small, Ive just compared your anchor and rope to longridges (picture taken a few years back), maybe you could fashion some thin'ish wire to make the ring bigger?
#17 Posted : 28 April 2010 00:25:23
Great job Timebob,thanks for shareing it with us
Macmedal
#18 Posted : 28 April 2010 01:33:44
AFter puddening the original ring I also discovered the ring was too small. I used McKays Anatomy of Victory to compare the ring size and made a new larger ring out of copper wire. I will post pics in my build thread.
Jamie
#19 Posted : 28 April 2010 08:16:56
Excellent macmedal, I would be interested to see those as I am gonna do the same thing ThumpUp
Macmedal
#20 Posted : 28 April 2010 10:17:25
Here is a picture of the difference in ring size compared to the original ring after I took it off.
Macmedal attached the following image(s):
This page was generated in 0.189 seconds.
