Attatching the Chainwales Options
GilShapley
#1 Posted : 26 May 2012 11:18:01
Got ahead on myself and painted the hull including the Channel Wale. Now I have come to attatching the chainwales where the advise is NOT to paint the channel wale as this might affect the adhesion of the glue. OOOppps. So rather than remove the offending paint I have used a method of attatchment similar to that when we attached various other components to the deck. I have drilled several holes in the chainwales and glues in pins with the heads removed, leaving approx 3mm exposed. Then offer up the chainwale to the correct position on the hull and use the pins to mark the hull. Drill the hull then glue and fix the chainwale in position. By the time you have also attached the supports with supperglue and pins it will not move. Jobs a goodun
Current Build:-
RussG
#2 Posted : 28 May 2012 11:24:10
Great Tip Gil, I have done the same but not yet attached the chainwales, Thought of doing it that way myself, so Im glad someone beat me to it and it works!BigGrin
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
This page was generated in 0.087 seconds.
